Tool Talk Discussion Forum
Galvanized tank for diesel fuel....
CaptRon
12-31-2006 08:21:13
Hey Guys,
I need a fuel tank for my diesel generator and have come across a like new galvanized water tank in an old camper. I originally had plans to use it as a roller since I know that galvanize and diesel fuel don't mix but the tank is the perfect size for the generator and when I took out the fill pipe I can see that the insides are like new.
Can I coat the inside with a tank sealer and use it? Maybe tumble the tank with rocks and sand to remover the galvanize?
Any ideas?
Thanks,
CaptRon
JMS/MN
12-31-2006 12:19:49
 Re: Galvanized tank for diesel fuel.... in reply to CaptRon, 12-31-2006 08:21:13
You're right about galv being bad for a diesel storage tank. Why not find a 30-55 gallon oil drum that's clean and make a little stand for it?
CaptRon
12-31-2006 15:02:43
 Re: Galvanized tank for diesel fuel.... in reply to JMS/MN, 12-31-2006 12:19:49
JMS/MN,
This generator is trailer mounted and so a 55 gallon drum on a stand won't work. Also, that size drum isn't going to fit on the trailer either but thanks for the reply.
CaptRon
Dale B
12-31-2006 09:28:56
As I recall , the problem with galvanized steel and diesel was that the sulfur in the fuel reacted chemically with the galv.Since virually all the sulfur has been removed nowadays , it probably isn't an issue anymore. Expeiment with a gallon of fresh fuel in the tank and leave it for a few weeks. If it blackens or discolors the galv. , better seal the tank If you wanted to be real cautious , you could use a tank sealer , such as "Kreem " etc.
