Broken Spring/Roll Pin in Jack Stand
Tyler (MD)
04-12-2001 15:57:12
I have a 3 ton jack stand. The spring/roll pin is broken allowing the stop to spin freely on the release handle. The hole appears to be 1/8 diameter. So I need to find a pin a bit larger than that. What type of pin comes in these? Stainless steel? What's the strongest?
Thanks,
Tyman
Ray,IN
04-12-2001 18:26:13
 Re: Broken Spring/Roll Pin in Jack Stand in reply to Tyler (MD), 04-12-2001 15:57:12
The roll pin is just a few thou. larger than the hole. Example: a .250in. pin will measure about 8-13 thou. larger. You may use a new pin to drive out the old; then the new one is installed, just be sure the new one is the correct length. If you aren't comfortable doing that, use a pin punch(they're.003undersize) that fits the hole. Thats my stratigy.
Thanks Ray!
04-13-2001 17:06:13
 Re: Re: Broken Spring/Roll Pin in Jack Stand in reply to Ray,IN, 04-12-2001 18:26:13
I picked up a couple of carbon steel pins (5/32 x .75) today for .15 cents ea. Fit prrrrfectly!
Thanks again,
Tyman
