Tool Talk Discussion Forum
compression tester flaws
Charles McNelly
12-29-2006 18:33:40
I bought a compression tester and I can't seem to get a good read. My Farmall B and W-6 have the large spark plugs. When I screw the tester in all is fine, it tightens up and when I turn the motor over it blows the 0 ring out from around the stem of the tester. For some reason they didn't put a large enough retainer behind the O ring. I tried another brand of tester, same problem. Has anybody else have this problem?
Charles
JT
12-30-2006 07:27:26
 Re: compression tester flaws in reply to Charles McNelly III, 12-29-2006 18:33:40
Never had that problem, just run a compression test on my H, should have the same size plugs as your B, no problems. Cheaper testers might have that problem due to the way the fittings are made.
dan hill
12-30-2006 03:44:52
I use an old tester with a tapered rubber end.Some real bad oil pumpers will have good compression.
msb
12-29-2006 20:48:04
Knock the center out of an old spark plug and the weld in a air connector male end. Be sure it is short enough so it will fit a deepwell socket.Attach a female chuck end to your compression gauge and you will have a good compression gauge.
Charles (in GA)
12-30-2006 14:39:21
 Re: compression tester flaws in reply to msb, 12-29-2006 20:48:04
You can buy "air holds" that are like spark plug shells with 1/4 pipe thread in them to install air nipples. Used in conjunction with -on the engine- valve spring compressors for replacing seals. Quite easy and much easier than knocking out the innards of a spark plug (which is extremely difficult and time consuming, last time I tried)
Charles
Bob
12-29-2006 20:41:53
Try an "O" ring with a thinner cross-section.
It will wedge into the threads better, and probably seal. It may get cut up, and have to be changed after checking a cylinder or two.
Or, if you have a friend with a lathe, have him cut a shallow groove in the gauge adapter for the "O" ring to sit part way down into.
Wisconsin Cowman
12-29-2006 21:48:19
 Re: compression tester flaws in reply to Bob, 12-29-2006 20:41:53
Never had that happen before. It depends on much you paid for one. Like the 22.00 Wal-Mart ones are junk. Buy yourself a good one.
