Using o/a welder to make cat. 1 landscape rake?
Dave 50 8N
04-11-2001 21:19:44
I'm a novice welder. Minimal experience. Been looking at the archives re: o/a and arc welding, etc.
I plan on just browsing internet sites for ideas/plans.
Questions I have are:
#1: Am I being unrealistic to think that my Craftsman o/a welder could be ok to do this? I think #5 (1/16th orafice) is the biggest tip I have.
#2: What's would be a good gauge square/angle iron stock to use for framing it up? Would broken out leaf springs (individual spring) work for some of the bracing?
Saw posts re: right setting on tip. Also re: tank draw rate of acetyline. And info re: burning up acetone...oops. did that. didn't know. Time to confess when I exchange.
Thanks in advance!
Dave
wrenchman
04-13-2001 01:34:27
 Re: using o/a welder to make cat. 1 landscape rake? in reply to Dave 50 8N, 04-11-2001 21:19:44
yes you can,but it's slower than he--.pick up a used 100 or 125 amp ac buzz box.they are cheap(around $100.),usefull and easy to find(usually).wouldn't use spring,welding usually makes them brittle.would work for tines though(bolted on).1-1/2 x 1-1/2 x 1/4 or 3/8 angle should make a good frame
Dave 50 8N
04-13-2001 08:20:20
 Re: Re: using o/a welder to make cat. 1 landscape rake? in reply to wrenchman, 04-13-2001 01:34:27
Thanks for the suggestion re: stock size!!! I hope to get to work on it soon. I have to... before the ground "sets up."
bob w.
04-12-2001 00:18:21
dave , i have used my oxy\ace tourch for welding .25" steal but it goes so slowly that i would recomed you buy an ac/dc arc welder it will make your project allot easier . also rember that welding on springs tends to take the temper out of them.
Bus Driver
04-14-2001 19:08:40
 Re: Re: using o/a welder to make cat. 1 landscape rake? in reply to bob w., 04-12-2001 00:18:21
Seems that just a few projects with the arc welder will save enough on the cost of gasses for the O/A to offset the cost of the arc welder-plus the saving of time mentioned by others. My supplier is really proud of his welding gasses!
