Tool Talk Discussion Forum
Forage harvester
Amir Sohail
12-28-2006 03:21:32
We need machine to chop windrow of wheat straw left behind by combine. Please advise which machine will be suitable for this task? Can we use forage harvester?
Your advise will be greatly appreciated.
RickL
12-28-2006 10:37:32
 Re: Forage harvester in reply to Amir Sohail, 12-28-2006 03:21:32
put the chopper attachment on the combine,most all of them had them
Dusty MI
12-28-2006 07:13:36
I would think a flail chopper would work, if your wanting to keep the straw.
Roger in Iowa
12-28-2006 05:59:51
What are you going to do with the straw? Are you just chopping to disperse on the ground? Do you want to keep it for bedding for animals?
A forage harvester can work, but dry straw is somewhat difficult to feed into a forage harvester as it is very slick. Straw also wears on the knives. It is especially difficult to handle or feed into the forage harvester if the combine is a rotary as the stems are broken into smaller pieces.
Easier to round bale and use a bale shredder to make bedding. Lots easier to store and process.
Need to know more info to give better answers.
Roger in Iowa
RustyFarmall
12-28-2006 07:07:51
 Re: Forage harvester in reply to Roger in Iowa, 12-28-2006 05:59:51
Maybe what is needed is a straw chopper, mounted on the combine?
