Tool Talk Discussion Forum
Newbie, Quincy 210 Compressor
tinknocker
12-27-2006 20:57:12
I have an older Quincy 210 compressor. I"ve never had a compressor so I"m not sure about operation. After searching this board I found that the largest motor this will except is a 2 horse running at 850 rpm"s which I now have it running at.
Is it a bad idea to run an older compressor at it"s maximum output? What should the discharge temperature be like at the head? It seems rather high although I have not measured it and it makes me wonder if I"m going to destroy it. Any opinions would be appreciated.
jeffcat
12-27-2006 22:46:26
 Re: Newbie, Quincy 210 Compressor in reply to tinknocker, 12-27-2006 20:57:12
Hope you changed the oil and put in straight 30wt non detergent. Make sure the air filter is new or nice and clean. Drain the water out of the tank every so often. Pat it on the head good night. That should be about all you need. Jeffcat
XRogerX
12-27-2006 22:13:30
It's running within spec, nothing to worry about. It's a single stage compressor, so it will run hot, no matter what you do.
