Tool Talk Discussion Forum
Milwaukee Sawzall
Glenn FitzGeral
12-27-2006 20:18:47
My brother got the above tool for Christmas. It is 9 amps. He said it only has a 3/4" stroke whereas all the other ones he's seen have approx. a 1.3" stroke. His cost $125. Is this a lesser tool? What is it designed for? He can still return/exchange it.
Thanks, Glwnn F.
Bus Driver
12-28-2006 16:00:24
 Re: Milwaukee Sawzall in reply to Glenn FitzGerald, 12-27-2006 20:18:47
The longer stroke works better on thicker materials. The debris captured between teeth must be ejected for the blade to continue cutting. The stroke on a reciprocating blade ideally should be long enough for each tooth to be clear of the material at a moment during each stroke. The chain saw really does accomplish this objective!
glennster
12-28-2006 05:58:57
the standard sawzall has the shorter stroke. the super sawzall has the longer stroke. i bought a super quite a few years ago thinking theonly difference was in the amp rating on the motor, the super being higher....more power huh? kinda wish i would have bought the standard with the shorter stroke, when plunge cutting, the super really bottoms out the blades and bends em quick. and if you bind the blade when cutting, it will give you a real good handshake!!!
MarkB_MI
12-28-2006 04:42:22
Dunno about the stroke, but the Milwaukee has the best mechanism for holding the blade of any recip saw. I have a Makita, and you can't believe how aggravating it is to tighten the blade with an allen wrench each time you change blades, only to have the thing loosen up when you use it. The Milwaukee has a bayonet mechanism that makes it quick to change blades, yet it never loses a blade.
Seems to me that a short stroke is a good thing on a recip saw, since it should allow you to work closer to a wall or whatever without having the blade hit it.
lucasss
12-27-2006 21:46:53
my sawzall has 3/4 inch stroke.does anything the longer stroked ones do. it works well on steel,wood, about anything. i like it better for plunge cuts.you cant go wrong with that brand..lucas
Rexalot
12-28-2006 05:06:55
 Re: Milwaukee Sawzall in reply to lucasss, 12-27-2006 21:46:53
I have the variable speed milwaukee sawzall with the "quick change" bladeholder.
I've used a Dewalt and in my opinion there is no noticeable difference in performance.
Keep the Milwaukee. The quick change blade feature is just as strong as the units using an allen head screw, and far easier to swap out a blade since you don't have to find the allen wrench.
That feature does have a drawback though. If you leave the tool where it could condense moisture (like in it's case in an unheated, poorly insulated, concrete floored pole barn, between winter/spring - hmm, I never would've thought... )the blade retaining pin can rust in place which means turning the cap to release the blade has no effect. If this happens then you'll end up disassembling the blade retainer and drilling out the frozen pin. Parts are inexpensive and replacing the blade retainer is simple. I've had no other problems with this saw.
To prevent this from happening, remove the blade and just put a few drops of oil into the blade retaining slot when it's going to be put away for awhile. It's worked for me since.
