Tool Talk Discussion Forum
Your Ideas on constructing a Pole Derrcik
RoySC
12-25-2006 12:10:08
Merry Christmas.
Taking it easy today....started thinking about building a loading rig / hoisting device on the front of a 1985 medium size truck, Chey C-60. The truck has a PTO driven winch mounted on the front. I've spent some time surfing the web on ideas / plans for a rig that I can mount on the truck and use pulleys and the existing winch to lift items for construction purposes. A few ideas I found on the web are a "gin pole" or a "pole derrick". I'm interested in an adjustable height....with a max. height of approx. 35 to 40 feet.
Any ideas / advice / suggestions on available information on building such a rig is appreciated
retired 5010
12-29-2006 16:43:32
 Re: Your Ideas on constructing a Pole Derrcik in reply to RoySC, 12-25-2006 12:10:08
I have built 3 boom trucks in the last 30 years. --if you have a use for one - you won't know how you got along without one - you want to use the shortest wheelbase you can find -it helps when your in close quarters. -you don't have to buy the driven PTO boxes they have out there. I always have - and still use a short tailshaft GM 3-speed transmission. you use reverse and 1 st gear on it. to drive your winch. don't get a boom too long on a small 1 ton truck because I have done that.-- you can run a jack out of the truck transmission to power the GM 3 - speed. gear out the back of the 3 - speed with #60 roller chain. to drive the winch . you want the ratio SLOW - in case you are inching the winch line up while you are pulling a engine. the one I have now is on a 74 CHEV C-60 with a cut down wheelbase.
D13
12-26-2006 06:34:45
As a lad, the local junkyard had a '50's 2 ton Chevy with a boom on it. Probably 4" pipe A frame welded to the truck frame right behind the wheels with big doubler plates, ran up 10' or so, braces welded to the frame at the cab and run up to the tip of the first, then another boom pole wlded to the cross piece of the braces and hanging 10' past the first. Gave about 20' lift on 3/4" cable, single sheave, PTO drive with brake on drum. Would pick up and move a station wagon and load it on his 2 deck scrap truck. Musta had 4000# of cast iron heads hung on truck, at least 1000# on the front. Had double trans with 1 in backwards so ultra low gears forward and backward.
Never be in a hurry, draw diagrams of where the weight is and where it can go. Keep the weight close to the truck and centered down the axis.
Think of a telphone pole setting truck, pole wieghs less than 10% of the truck. They don't do that because of the gas mileage, it's so that the arm leverage doesn't tip the truck.
oldcraneguy
12-25-2006 13:38:03
Flirtin Wit disasster are we?...lol Well Im sure you got your reasons so I wont lecture, Basically 2 ways to make your boom, either an A-frame boom(more stable, stonger heavier,harder to raise and lower) or a monopole type with gussets on the bottom(lighter, weaker,less stable, easier to raise and lower and telescope) and an A-frame boom cable arrangement but ifin it was me Id look around for an old cherry picker that you could mount on your truck on the back! 35-40' dont sound like alot but if you get a few hundred lbs up there and go to move it a few feet and discover a pothole under the puddle and its all over but the cleanup and the cussin.. How much weight are you gonna be pickin? Does you winch have an automatic brake? At any rate if you mount a boom on the front your gonna need to build a mast behind the cab to winch the boom from, do you want to use the winch to hoist the load or the boom? keep in mind that you can get 12v boat trailer winches that will pull more on a single part than the front end of your chevys gonna want to tote. We had an old dodge power wagon that had a A-frame on it that was Im guessin less than 20' and the guy that rigged it up just used 2 cables shackled to the mast but it was a pain in the butt every time ya turned around we had to get 3-4 guys to help us take it down/off whenever we needed to take it anywhere at all. Even when we got a blown up dump truck there and figured we could just run up against it and take the cables loose it was still a big pain to deal with. If you decide to use your winch to R/L the boom you can put your dead end in the tip and just have a sgl sheeve on the mast then back to the tip and down to the winch, that will give ya 2parts of line, I figure 3/8" should be plenty. I'll be curious how ya make out so post us a pic (shiney side up)...lol...just kiddin
P.S. the more weight you have in the bed the more stable the whole rig will be...Good Louck, Don
