Tool Talk Discussion Forum
insert bearings
cranky
12-24-2006 12:29:49
I always thought that when you grind a crank shaft that you would need oversize bearings or inserts, but I think they call them undersize bearings. The crank is what is undersize. So you would need oversize bearings on an undersize crank.
msb
12-25-2006 12:02:10
 Re: insert bearings in reply to cranky, 12-24-2006 12:29:49
Just remember its under the size of the original cranhshaft size.Thats how I keep it straight in my mind.
lucasss
12-24-2006 16:33:38
in the rebuild world we call brgs for reground cranks undersize bearings.boggles the mind doesnt it? lucas
Gerald J.
12-24-2006 15:42:28
But since the finished bore of the bearings is smaller than the original you could call them undersized.
Gerald J.
Jon Hagen
12-24-2006 14:37:33
Yep,the crank journal is ground undersize to eliminate the worn surface,so the bearing shells have to be overly thick walled to give an undersize bore.
