dcfan
12-24-2006 12:45:41
Re: Motor Brushes in reply to Jon Hagen, 12-24-2006 07:59:40
No not a typo, i run 3 of them all together or seperatly either direction, and your close with the sub,its asurface vessel although i don't enjoy having the bow put under,been there didn't like it:( Those motors are in a ice breaker, triple screw, one per shaftline, generation is 6600vac transformed and rectified to 900 dc. generation capacity is 35,000hp with losses we end up with the 10,000 shaft hp, times 3. [30,000] These were built in 1966[ yes 66] and are still great units, picture 1 person 6ft, by high 200's in weigh. he can enter the casing on one side. slide down and under the comm/brush rigging turn around and exit on the opposite side. if that gives you an idea to size, casing/housing is a box 10wide x 12long x 12high in feets:) and final tibit of trivial: factory specs state full ahead to full astern directional change rating is 4 seconds at maximum torque/shaft speed of 118RPM, and again that is 4 seconds, impressive and scary electric stress noises/diesel strain when it happens. hope it was what you wanted to know
