Brazing
Mark
04-10-2001 09:59:19
I have never brazed before and I was wondering if there is anything special I should know about oxy-acetylene brazing. I have to do some minor attachments. I have a miller mig and have done much with that but I think the temp is too high for this metal I am now working with.
Mark
T_Bone
04-10-2001 17:48:22
 Re: Brazing in reply to Mark, 04-10-2001 09:59:19
Hi Mark, Braze welding is alot like Tig welding. It takes both hands working together to make a good weld.
You can braze weld just about any metal of any thickness. I've brazed gold that is thin as ciggerate paper. The neutral flame setting is the most important and this is done buy setting the acetylene then oxygen setting to where the outer flame cone just comes back to the touch the inner flame cone and no more. The flame cone I'm talking about is the one closest to the tip and is white or lite blue. When adjusted properly the flame cone nose will be rounded, a sharp point cone is too much oxygen and a feather cone is not enough oxygen. This is the welding part of the flame and thats why it's so important. Play with this setting until you see what I have described so you'll know what to look for.
The outside flame is from mixing act/oxy and is orange to blue and is the longest flame. This is the preheat of the weld puddle and more heat for thicker or less for thinner metal. Tip size limits the preheat temperature. Larger tips are for heavier metals but use the smallest tip that a joint will take.
This is where a Victor 100 torch really shines. Because of it's small mixing body and a small tip, big great looking welds can be made or small Tig like welds can be made. The only "tell tell" sign is the flame patteren on the base metal. I do suggest 10ft length of 1/8" to 1/4" hose so the torch has free movement and lots of orperator control.
A flux is not needed if you,
1) clean the joint (grind scale) and the "filler rod" with emery paper
2) the filler rod is not removed from the outer flame at any time.
When you need flux, use borax available at any store. You will know when you need flux as the metal won't take the filler rod providing,
1) you have throughly cleaned the base metal and filler rod
2) your using the correct filler rod for the base metal.
3) Your using the correct heat & flame setting.
All metals needs to be cleaned as they "all" oxidize, bar none. Some can be cleaned with a twisted wire brush on a drill motor, some need a grinder, but the end results the scale has to be removed for "any" type of welding. Anything less is a bad weld or a weak weld!
I find that aluminum stick filler rod with a flux coating works well for brazing because aluminium is such a dirty metal as it's porus and intraps oxygen as well does cast steels/irons. A stip of aluminum and borax would work just as well but I usally have some aluminum stick rod laying around that someone gave me.
T_Bone
another excellent post by T_Bone
04-13-2001 11:36:22
 Re: Re: Brazing in reply to T_Bone, 04-10-2001 17:48:22
Thank you for the refresher course.
Wade
Your Welcome! (nt)
04-14-2001 04:56:31
 Re: Re: Re: Brazing in reply to another excellent post by T_Bone, 04-13-2001 11:36:22
Mark
04-11-2001 04:29:29
Thanks T Bone.
I have a Victor control handle so I should be able to start on this project soon since we expect 8" of snow today.
Mark
