Tool Talk Discussion Forum
battery charger modification
Stumpalump
12-21-2006 21:29:55
Can I modify my old 10 Amp battery charger to be safe for Optima gel batteries? Is the difference just a lower output voltage? Can I use my old charger for a short time or will it fry the battery?
T_Bone
12-22-2006 03:39:35
 Re: battery charger modification in reply to Stumpalump, 12-21-2006 21:29:55
Hi Stump,
For $18 you can buy a 2a charger with the new PMW regulation circuit that will recharge a battery in 1/2 the time as the old regulators.
PMW regulation is good for any type of battery.
A yellow top Optimia is 75a/hr so if your at about 38a down when you need recharged, then it would take less than 24hrs for the 2a charger to be back too 100% battery.
Wally World sells the 2a Schmachker trickle charger for $18. I've had one for a year and it seams decent for what I need.
T_Bone
Greg_Ky
12-21-2006 21:36:50
I have used my standard battery charger"s on my optima"s for years and never had any problems.
Jon Hagen
12-22-2006 00:16:22
 Re: battery charger modification in reply to Greg_Ky, 12-21-2006 21:36:50
Same luck here,a small charger without a fast or boost charge position will not dry out an Optima if it tapers down to 2 amp or less and is not left on indefinatly. Small point, but the Optima batterys are an AGM absorbant glass mat battery with liquid electrolyte soaked into the fiberglass mat seperators. The gel cell battery has a almost jello like semi solid electrolyte. They are a totally different animal that plays by a different set of rules. The spiral cell AGM battery is a superior cranking battery with a very long life under hard use.
