Ah, RC airplanes... I haven"t flown mine in several years, since we brought horses home to the pasture. So, since I"ve not been into the "hobby" for awhile I don"t have any familiarity with the brand you quoted. However, If I were buying my first plane again I would select a "trainer" model, something in a "40" size (denotes an airframe that is propelled by a .35 - .50 engine, and there are multiple engine mfg"s), with a preference to a high wing design. If your proposed runway is on the rough side, a tail dragger would be better than a tricycle gear, although I would suggest the tricycle geared airplanes for better ground stability. To cut your cost"s I would buy an "ARF" or "almost ready to fly" unless there is something already built hanging off the hobby shop ceiling should you not choose to build your own. Follow the directions for setting the airplane up and for "balancing". If your going to be serious about this hobby then buy a Futaba 6 channel FM radio, otherwise any decent 4 channel is all you need. This will give you the ability to control all axis"s and throttle. Stay away from AM radios and used radio equipment unless you can try it out (on the ground... you should be able to walk 150+ feet away from the aircraft with the antenna collapsed and still have "control".) I estimate that you will have atleast $250 and as much as $500 getting started, if you figure Airplane, radio, engine, fuel transfer pump, and an electric starter (unless you want to hand prop.. watch the fingers - kick backs hurt!) Since your going to invest some $$$ and if you haven"t flown one before, you might want to consider some type of lesson, maybe get a PC based training program. RC planes fly very much the same, require the same type of control inputs to stay under controlled flight. There is also the added confusion factor of control when the aircraft is flying to and away from you. Left becomes right and vice-versa. There is also the speed factor. Things happen relatively fast with an object this small. Don"t fool yourself into thinking you"ll never crash... even if your careful. You will. Despite the cost and potential for ruin flying RC was always alot of fun. Good Luck.
