Tool Talk Discussion Forum
Shortening the chain on chain saw
Willy P
12-19-2006 16:25:20
How do you shorten the chain on a saw chain? I got one that needs a link taken out of it and not sure which link to take out,if I take a cutter link that will leave 2 cutters on the same side,I guess that I need to take it to the saw shop and let them do it. Thanks
dan hill
12-23-2006 03:34:26
 Re: Shortening the chain on chain saw in reply to Willy P, 12-19-2006 16:25:20
Chains that are stretched beyond bar adjustment are ready to break.Short tooth chains dont cut well even when properly sharpened.Its false ecomony to run worn chains.A friend cut the back of his hand with a chop saw .Medical costs were 13 grand.Another friend almost lost his thumb to a worn chain that broke.I sharpen chains and wont touch badly worn chains.I use a chain saw and like my fingers.
TomTX
12-21-2006 05:40:03
If you are going to cut very much wood, then get a new sprocket and 2 new chains. You chain if probably worn out, and if you keep using it so will your sprocket. Tom
jokers
12-20-2006 10:19:59
Let me preface my statements by saying that I have had to shorten a few chains of my own through the years, but you should know that chain "stretch" to that extreme is indicative of running dull or improperly lubricated chain. I emphasize the term stretch because what you are witnessing is not really stretch, it is really indicative of significant wear on the rivets.
Correct the issue causing the long chain if it is a recurrent problem. Sometimes though, for example bucking dirty skidded logs on the deck, there is not much you can do to get a reasonable interval between sharpenings but overall a sharp chain is much more productive than a dull one even when you factor in the time that it takes to maintain the chain to keep it sharp.
Think about this, if your chain is getting longer and your drive sprocket is getting smaller through normal wear, what is going to be the result? Increased wear and loss of usable horsepower for cutting.
The best tools for breaking and making chains are the bench mounted type but the Granberg Break-N-Mend also works very well. It also has a feature for reshaping the rivet should you need to. I`ve found the $5 anvil and punch type tool to be less than satisfactory and I always ened up with a sore thumb after the shock from hitting the punch with the hammer is transmitted to the bone.
Having two cutters in sequence on the same side is not an issue. As an example consider that the smaller Stihls running .325 chain on 16" and 20" bars require 67 and 81 dl respectively which always results in this arrangment. My practical experience is enough to prove to me that it`s not important but for anyone doubting me, surely you must know that Stihl could have bars made that use an even number of drivers if it were important.
There is nothing wrong with running a chain until it can`t be filed anymore if the rest of the chain does not display signs of excessive wear. If you don`t run them this long you are throwing money away. Instead buy some chaps, which you should wear anyway, and use your chains right to the limit.
Steve Crum
12-20-2006 08:37:01
I just drop 14 bucks at tractor supply and get a new chain. When the adjustment is all taken up the chain is usually whipped enough that it is due to break soon. Dad used to be a tightwad and run chains until they couldn't be filed anymore. This practice stopped after I got a bunch of stitches in my left knee due to a worn out chain that snapped.
big jt
12-19-2006 22:18:28
Darn near all saw chain's have a spot either where there is two links on the same side or a extra tie link making a gap. Doesn't affect operation and makes sharpening easier. Start at that spot and switch to the other angle first time it comes around second time around you are done.
Saw or small engine shop will have the tool to take a link out. Check for adjustment first though.
hth
jt
theo43
12-19-2006 20:03:01
isnt the bar adjustable?
jdemaris
12-19-2006 18:54:14
The two cutters hurt nothing. Some people take an extra one out from the other side - and then you've got a section of chain with no cutters at all. The best way to work on the chain is with a chain-press and a rivet-spinner. That's what any good saw shop should have. And, usually, when putting it back together - and new link is used and peened. But - we used to sell little $5 chain-breaker - just a little anvil and pin you hit with a hammer. Anvil has grooves for .404, 3/8, .325, and 1/4 " chain. They work - just not as neat. I've seen many chains get fixed, links replaced, shortened, etc. with just a hammer and the $5 tool. You don't even have to use a new link - as long as youd don't grind the old one out - and drive it instead. That way, there's enough metal left to re-peen it.
KEH
12-19-2006 17:00:04
I always take mine to a saw shop. It takes a special tool. Yeah, it leaves 2 cutters on the same side. Dosen't cause any problems, makes it easier to tell where you are when sharpening chain.
KEH
2x4
12-19-2006 16:56:15
saw chains dont have master links. Easiest way is to grind the heads off rivets of a tie strap, then punch them out with a hammer & punch. The tie strap is the strap that connects one drive link to another. Drive links are the links that stick down & are driven by the sprocket. Then remove the drive link by taking out the next tie strap. Now get a 2 piece repair tie strap & use it to reconnect the shortened chain. Flatten the rivet heads with a ball peen hammer.
Crem
12-20-2006 07:13:43
 Re: Shortening the chain on chain saw in reply to 2x4, 12-19-2006 16:56:15
I grind off the heads of the rivets like you do and then use a spot of weld to hold them back on.
