Tool Talk Discussion Forum
question for you welders
banjo
12-19-2006 08:15:01
I have some rods that do not have any numbers. The only identifiers are a black and red dot. do any of you know what they are for?
PM-OHIO
12-19-2006 17:05:44
 Re: question for you welders in reply to banjo, 12-19-2006 08:15:01
This link may help you.
Link
PM-OHIO
banjo
12-19-2006 17:19:34
 Re: question for you welders in reply to PM-OHIO, 12-19-2006 17:05:44
I went to that site but i can't click on any of the topics.
135 Fan
12-19-2006 15:30:18
They haven't used the color dot system for years. The only recent rods I've seen are lincoln that some types have dots.(6010) What colour is the flux and how thick is it? You might be able to compare it to new rods. How does it weld? They're probably old rods and I wouldn't use them on anything very critical. Light duty stuff would probably be OK. You'll be able to tell the most by welding with them. Hope this helps. Dave
Bus Driver
12-19-2006 14:24:33
Often an experienced welder can weld with one of the electrodes and make a reasonably good evaluation of the type. He will usually know if he encountered similar ones before.
Stan in Oly, WA
12-19-2006 11:02:40
Hi mj,
Lincoln's Procedure Handbook of Arc Welding color chart for identification of stick electrodes by colored dots does not list red as a color which was used. Good luck.
Stan
mj
12-19-2006 10:11:49
Are the color spots both on the uncoated rod or is one on the flux?
banjo
12-19-2006 16:53:09
 Re: question for you welders in reply to mj, 12-19-2006 10:11:49
For the most part the red dot is on the flux and the black is on the uncoated portion. These are 1/8 in rods and the flux coating is a gray color.the thickness is about normal for a 6011 rod.
I know these are old rods, but was wondering if they might be hard face rods.
TimV
12-19-2006 19:17:29
 Re: question for you welders in reply to banjo, 12-19-2006 16:53:09
If you think they might be hard face rods, lay a bead down and take a file to it. You don't have anything to lose--maybe lay down a bead of 6013 or similar as a "control" and see how it compares.
T_Bone
12-19-2006 23:41:45
 Re: question for you welders in reply to TimV, 12-19-2006 19:17:29
Hi banjo,
From your flux description along with using a black spot color with a red body (reverse colors of what you have) that would be 6028 or decking rod.
Your standing bent over with the rod in the end of the electrode holder then you burn a hole thru the decking to the bar joist making a round weld button, let cool, then move and repeat. a real back breaker of a job!
Tim makes a very good argument for a trial run.
Usually a electrode with a thinn flux coating is made to penetrate with very little flux interference on the molten puddle, like 6010 or 6011 does.
T_Bone
banjo
12-20-2006 01:28:25
 Re: question for you welders in reply to T_Bone, 12-19-2006 23:41:45
well the only rods i have to compare them to are 7018,6011. I do very little welding, except for repairs on stuff around the farm.
I didn't compare the thickness of the flux but trying to go by memory. the flux may be a little thicker than a 6011 but i dont know if it is as thick as the 7018. Memory may not be all that accurate. but the flux is gray and the red dot is on or close to the flux/uncoated portion and the black dot is closer to the end of the uncoated portion.I have no idea how old these rods are as they were in my Grandpas shop.
there are some other rods also that are reddish brown flux color but i cant remember if they have numbers or not.They are pretty skinny. thanks
