Tool Talk Discussion Forum
Welding gas
Tommy Bonds
12-18-2006 12:56:16
I have a wire feed welder, and am considering adding the gas to it to use as a MIG welder instead of the current Flux Core for general light steel (under 1/4") repairs.
I see a lot of people use a mixed gas as apposed to straight Co2.
Are mixed gases that much better?
Which ones?
How much more expensive are they to refill?
Does the tank cost more?
Do they require special regulator or anything?
And, if not used often, won't the gasses settle out? Is it required to shake the bottle after it sits around (for a long time?) to ensure the proper mixture?
135 Fan
12-19-2006 16:30:12
 Re: Welding gas in reply to Tommy Bonds, 12-18-2006 12:56:16
I agree with MarkB MI. Stainless often requires a triple mix shielding gas. It usually requires a more sophisticated welding machine as well with adjustable slope and/or inductance control. I used to have a 400 amp Miller diesel welder that was originally used for automatic pipeline welding. It was a constant current, constant voltage power source with an arc stabilizer and adjustable slope. I used straight CO2 but was using a very high end machine. I did have the flow meter freeze up a few times when doing bigger jobs. You do get more spatter with CO2. C25 gas is nicer to weld with. Mig welding is a low hydrogen process like 7018 and makes a stong weld with low temp. impact strength. Straight polarity self shielded flux core is not as strong, has less penetration and would be a closer comparison to 6013 or possibly 7014. No contest for strength. Mig is used for pressure vessels and piping for root passes. Most pressure shops can't use flux core wire even when using the much stronger gas shielded (C25) flux core wire. I'd use C25 gas for worry free flow and little or no clean up. BTW the C25 gas stays mixed. Hope this clarifies things for you. Dave
prwttsh
12-19-2006 04:27:57
I've never seen where the threads were different from co2 to the argon mix.
Stan in Oly, WA
12-19-2006 03:28:33
Hi Tommy,
As for prices, you'd be better off checking the prices from the supplier you'll be getting your equipment and gases from. Those are the real prices as far as you're concerned; what people pay in other parts of the country won't do you much good.
CO2 is cheaper than CO2/Argon mix (C25) but whether that's an important issue for you depends on how much welding you do. If you weld more than 10 hours a week, the difference in price might be meaningful. If you weld once in awhile the cost of the shielding gas might be the least important consideration. I prefer welding with C25 and I wouldn't use straight CO2 if it wasn't going to save me but $25 a year. I'd use it to save $25 a month though (probably.)
One way you can buy tanks from a supplier like Airgas is on a sort of rotational basis. You own the tank you have until you take it in for a refill. When you pay for a new tank of gas you leave your empty and take a full tank. Then you own that one. (If you prefer to own a specific tank you would have to drop it off to be refilled and pick it up later, plus being responsible for the cost of pressure testing every 5 years, I think.) An advantage to this sort of ownership is that you can go from CO2 to C25 and back while deciding what you prefer and the gas supplier will make the price adjustment either way. They're thinking in terms of getting your business for the rest of your life rather than putting the screws to you for a few bucks one time. Or else they're pretty screwed up and it would be worth your while to find someone else to deal with.
All the best, Stan
MarkB_MI
12-19-2006 03:11:32
The short answer is that you will get a nicer weld with an argon/CO2 mix, but it will cost you a little more money.
A longer answer is that there a many different welding gases for MIG, depending on what you are welding. There are special gases for stainless steel and aluminum.
Note that CO2 is NOT an inert gas. Consequently you will get deeper penetration with straight CO2 than with an inert gas such as argon or helium. The typical 75% argon/25% CO2 mix is a compromise that gives a nice, clean weld with reasonably deep penetration.
T_Bone
12-18-2006 21:24:52
Hi Tommy,
Here is a reprint of my welding gas topic that may be what your looking for.
There is no difference between a GMAW or FCAW weld as too the quality of weld achived thru either weld process.
Co2 regulators for Mig generally require no special external heaters. The abnormal would be having to add a gas heater.
There's several items that control how much cover gas flow is required while Mig or Tig welding. Lets start off with how a typical flow meter/gauge works.
Gauges:
There are two basic types of gauges:
1) flow meter:
A flow meter has two gauges on the manifold assymble:
a) The high pressure gauge that reads tank pressure contents in PSI.
b) The "caliberated" gas flow meter that controls cover gas flow measured in cubic feet hour (CFH).
There are two basic typical flow meter configurations, square vertical dial, and round vertical dial. Both use a center steel ball to denote gas flow.
Each side of one type of a typical "caliberated" square vertical flow meter is marked with a Argon flow scale, a Helium flow scale, a Carbon dioxide scale, and a Nitrogen scale. Why?
Each cover gas has a different weight thus will flow more or less CFH when comparred another gas. This is why I used the term "calibrated" flow meter as it accurately reads and measures other types of gases. This will become useful when using a welding process that requires different types of a mixed cover gas, like Mig welding Aluminum.
You can buy a premix gas cylinder (higher gas cost) that "maybe" be exactly what is required or mix your own gas with seperate pure gas cylinders (lower cost) that will always be what is required.
One flow meter also can accurate measure 4 different types of gas and once again at a lower cost.
The round verticle dial is read from the "calibrated" center dial and typicaly covers several different types of gases.
This type of flow meter typicaly measures 5 to 200 CFH depending on the type of gas being metered.
2) Round flow gauge:
A typical round flow gauge has two gauges on a manifold assymble, however there are one gauge round flow gauges:
b) The "caliberated" gas flow meter gauge that controls cover gas flow measured in cubic feet hour (CFH).
c) A one gauge round flow gauge only measures cover gas flow and not cylinder contents.
This type of flow gauge is not as accurate as a flow meter and usually only measures one type of gas. I do have one dual round flow gauge that measures Argon and Carbon dioxide. This dual gauge is marked with AR numbers on the out side scale and the Co2 numbers on the inside scale.
This type of gauge typicaly measures 0 to 30CFH.
What controls how much cover gas flow is needed?
When you do not get porosity with-in the weldment while welding!
What normally happens while with low cover gas flow, is tiny gas bubbles form on the face of the weld from the oxygen thats allowed to enter the weld zone, called porosity. As the cover gas decreases the porosity travels deep with-in the molten puddle to the root of the weld. When this happens then the weld needs removed and rewelded. Notice as your grinding out the porosity filled weld of just how deep the porosity can penetrate.
While welding carbon steel, you will notice the arc sputter then porosity form on the weld face then porosity proceeds thru out the weldment.
While welding SS, you will notice alot of carbon forming on the weld face. As the cover gas decreases, porosity once agains forms on the face first then proceeds thru out the weldment.
While welding Aluminum, the enitre weld will have porosity thru out almost 100% of the time. The torch cup size determines how the cover gas is spread over the weld. A #10 cup will spread a wider gas flow area than a #7 cup. How far the cup is held above the molten puddle at a given gas flow will determine adaquote gas coverage.
A gas flow of 15CFH maybe adaquote gas coverage with a #10 cup while at a 1/4" arc length at 140amps, inside a shop but not outside.
As the welding amperage increase so does cover gas flow rate as the heat pushs the cover gas away from the molten puddle. While 15cfh maybe adaquote at 150amps, 30cfh maybe needed at 225amps and 45cfh at 275amps.
Hand and body positon around the torch will greatly influance gas flow rate needed.
Welding inside with no external air current decreases gas flow rate.
Clean weld joint preperation will take less cover gas than a dirty joint.
AR or Co2 uses less cover gas than a HE mixed cover gas.
A v-groove joint will take less cover gas than a butt weld joint.
A weld joint using a chill bar or backing bar will use less cover gas than a open root weld.
I'm sure I missed something else but I think this will help. And I bet you thought I was going to say, ahh just use 20cfh... LOL
T_Bone
135 Fan
12-18-2006 17:33:31
The same regulator or flow meter will work however you need an adapter as the cylinder threads are different. C25(75% Argon,25% CO2) gas has less spatter and a wider flatter bead than CO2. CO2 has a narrower bead and more penetration. One problem CO2 has is that the regulator can freeze up stopping gas flow. You can get special flow meters with heat sinks or electric heaters in them but they are expensive. Some people have put a light bulb on the regulator to stop freezing. C25 gas is preferred because of the nicer welding characteristics. It costs more but you can do a lot of welding with a cylinder. If you just have a small wire feed welder, the gas shielded MIG will be a lot stronger weld than the self shielded flux core if done right. Dave
Tim Casbolt
12-18-2006 15:45:40
Same regulator as CO2. Might need a threaded adapter to fit the bottle.
traper
12-18-2006 14:19:07
To use gas outside must calm day no wind.
glennster
12-18-2006 13:07:51
shielding gas will depend on what your welding. if you are doing general welding on mild steel, the 75/25 mix argon co2 will be fine. if you dont have a regulator already, get one set for 75/25. the gases dont seperate over time. depending on the bottle size, the fills will run any where up to $80.00 for the 330 bottle, to maybe 20 -25 for the small bottle.
