Tool Talk Discussion Forum
5000 watt coleman generator
ross in ns
12-18-2006 03:49:59
hi all wondering if this generator 5000 watt coleman it has a 10 hp techmsch engine not spelled correct i know local hardware store has them on special this week 200 bucks of regular price i can get this for 700 canadian just wondering for light duty use is this a good one or not thanks ross
john cub owner
12-19-2006 07:09:25
 Re: 5000 watt coleman generator in reply to ross in ns, 12-18-2006 03:49:59
I have a 4k Coleman with a Briggs engine I bought 15 years ago, and while it only gets occasional use, when it is used it is serious. 10 years ago, it ran 3 1/2 days continous duty, last summer 4 days contiuous at full load after the storms, and 2 weeks ago 2 days contious duty at full load. it runs 8 hours on a 5 gallon tank of fuel, and at full load does require a small amount of oil every 4th or 5th tank of fuel (that is 25 gallons of gas, or about 40 hours of run time. M only complaint is it needs to be a little bigger.
JT
12-19-2006 07:05:46
Ross,
Don't know what $700.00CND, translates to USD, but for 700.00USD, you can buy a 8550 surge 5550 running watt Briggs generator. Decent little unit for the money. Been a good genset in my opinion. Colemams are not bad, but they are not a real high quality genset. Jim
dan hill
12-19-2006 02:14:29
Coleman generators have a plastic end bell on the generator that lets the bearing spin.End bell shot.
buickanddeere
12-18-2006 20:33:01
Can't hurt to take a look at Generac. They built the OHV 45 degree slant engine that Honda copied. They even have an oil filter. Price is right too. I have an old pelter of a 4000XL here with unknown thousands of hours from being run all day for six days a week for a Menonite construction company. The old swine still cranks up, runs and starts electrical loads better than a new 5000W Coleman.
RodInNS
12-18-2006 18:08:44
Ross,
I dunno about the 5000 W model, but we've got a 10000 W here on the fire department. It's Briggs powered. It works fine, but the Briggs will wear you out before you get it lit. We've also got other old Briggs engines around, and one Tecumse. They've got a starting routine too, and want some warm up time before they'll work right or idle. Not a whole lot bad to say about them, but they just don't start or run like the Honda's. We've got a few around between the fire department and the farm, and they all start easy, often on the first pull. If they don't, they need tuning.
If it was me, I'd be watching the Merchant for a good used one with a Honda OHV engine. Good luck.
Roddie
135 Fan
12-18-2006 17:51:32
Tecumseh makes several models of engines. I have a floating water pump with a pressure lube tecumseh engine. The pumps have also been fitted with Honda and Kawasaki engines. In talking directly to the manufacturer, they said the Tecumseh lasted the longest as long as the oil was changed every 6 to 8 hours. I was never a fan of Tecumseh but when according to the OEM this particular one will last 1500 to 2000 hours longer than a Honda or Kawasaki, I'll just change the oil more often. It's only 6 hp but the pump is $2000. Tecumseh have been the engine of choice for snowblowers for eons. A lot of high end lawn mowers are using Tecumseh as well. The Coleman generator is a light duty residential model with a lower grade engine that is noisier. I bought a Robin Subaru generator that is as good or better than a Honda for a lot less money. Robin are the #1 engines in Japan. Hope this helps. Dave
dan hill
12-23-2006 04:27:56
 Re: 5000 watt coleman generator in reply to 135 Fan, 12-18-2006 17:51:32
My band saw mill has a Honda on it .I know the fellow who builds them.He tried Tecumseh NG.I saw a lot of 6hp tecumseh with thrown rods and much rewind trouble.
old art
12-18-2006 17:35:48
the engine not the greatest repaired one the oil capasity only 1& 5/8 PINTS yes PINTS not enough to cool it it is a splash system no oil pump.
the low oil sensor not a good item. you can do much better with honda or briggs..old art
Tim Casbolt
12-18-2006 15:51:34
Not sure about the going rate in your area, but that sounds a little overpriced to me. Especially for one with a Tecumseh engine. I'm not a fan. They're quite loud, and I've never had much luck getting them to hold a tune.
Briggs Industrial
12-18-2006 14:31:43
B&S **builds 3 levels of quality small gas engines. (Honda *builds two) B&S's top of the line are called Vanguards and are as good as or better than any other small gas engine built. I would choose one over any Kohler any day any time. Tecumseh need not apply!
I don't feel the Honda OHV model is over rated, but they also sell a lower end motor that is called OHC... There's a BIG difference between these two motors...
I'd buy a better quality gen. set if it was me.... (read Honda of Yamaha)
* Honda does NOT build all of there motors in Japan any longer. Some are built in third world countries.
** actually Briggs has there Vanguard motor build in Japan by two or three different companys depending on the size of the motor.
phil lowe
12-18-2006 14:08:25
hey Ross where in NS are you ,,I might need one of them Genny's too!!!
mph
12-18-2006 09:45:26
I would steer clear of tecumseh. Had a lot of gen. sets over the years, worked in n.w. woods.Hard to beat a Honda or a ind.B&S.
Bob M
12-18-2006 05:48:25
Ross - Like Bus Driver, given the choice I go with a generator with the B&S overhead valve engine. Particularly if it's gonna get used a lot.
HOWEVER I've owned a Coleman/Tecumseh 5 kw generator since 1991. It's never given me a lick of trouble in 15+ years of emergency backup service (averaging probably 10 hours of run time/year). And it starts always on the 2nd pull regardless of the weather. For the money I paid I'd buy another just like it...
mj
12-18-2006 16:18:27
 Re: 5000 watt coleman generator in reply to Bob M, 12-18-2006 05:48:25
Same story here; almost exactly. AND I won"t pay an extra red cent for a Honda; I"ve had better luck with B&S, Kohler and Tecumseh.
Bus Driver
12-18-2006 04:53:24
Personally, that is not the generator I would choose. In over 50 years of owning and operating small engines, I have had only one Tecumseh that was a good one, and it was a very good one. The remainder were real junk. I am unwilling to try them again. I have had only one bad Briggs and it was not terribly bad. Never owned a Honda small engine, but it is difficult to find an owner who is displeased.
big fred
12-18-2006 10:59:15
 Re: 5000 watt coleman generator in reply to Bus Driver, 12-18-2006 04:53:24
I find the Honda on my pressure washer is often hard to start. It always starts, mind you, but sometimes I'm about ready to drop-kick it before it does.
And the Tecumseh on my wood chipper always starts second pull.
I'd take a nice Briggs and Stratton over either of 'em...
Stumpalump
12-18-2006 10:33:18
I was in the town of Techumse last year. The small engine factory was going under untill they got a contract to build Briggs. Thats like Ford building Chevys. Hondas are a little over rated IMHO.
