Tool Talk Discussion Forum
Re.drill and tap
tdg-in nc
12-17-2006 19:44:07
For 7/16 x14 use a 23/64 size drill bit -7/16 x20 (fine threads) use a 25/64 drill bit .If you have already drilled it 3/8 you should be o.k. You will have less than 100% of threads.
DADDY E
12-18-2006 19:38:37
 Re: Re.drill and tap in reply to tdg-in nc, 12-17-2006 19:44:07
AS OTHERS HAVE SAID, THE 3/8dia. HOLE IS OK FOR CAST IRON USING A 7/16 dia. NC BOLT. DON'T USE A FINE THREAD BOLT IN CAST IRON, THEY WILL FAIL IN SERVICE. TAPING CAST IRON IS EASY AS LONG AS YOUR TAP IS SHARP. [FROM AN OLD TOOLMAKER].....ELDON IN ONT.
