Tool Talk Discussion Forum
Hobart handler 140 wire welder
Eddie Jones
12-17-2006 16:14:00
Thinking about buying a wire welder. Can anybody tell me the pro and con of the hobart 140 wire welder? Thank in advanced Eddie
DumOleBob
12-18-2006 08:23:34
 Re: Hobart handler 140 wire welder in reply to Eddie Jones, 12-17-2006 16:14:00
My Hobart is just fine - as long as you limit yourself to 1/4" MAX!
Frankly in some cases I like it better than my 250 because it is so portable AND runs on regular household current as opposed to 220.
jpuleo
12-17-2006 21:12:18
Mine was great untill some dirtbag stole it off my deck.
RobertTX
12-17-2006 20:16:19
I have had the HH 135 (which was the previous model) for about 4 years. It has been excellent, I have replaced a lot of sheet metal with it. I am not sure about the gear issue the other guy mentioned, ask your question at the weld talk (Hobart) site. You will get very good responses.
Jerry (KS)
12-17-2006 17:39:44
Check the wire drive system in the Hobart then look at the Miller. Miller makes both Hobart and Miller. I don't think you will find any plastic gears in the Miller. You will pay about $100 more for the Miller over the Hobart..
rodgernbama
12-17-2006 17:32:18
I've had one about a year or two. It's a good welder for 1/4" or less metal. One thing about mig welding is the metal has to be shinny to get an arc. If metal has rust you have to grind it. Hobart, Miller or Lincoln all make good mig welders.
varmint
12-18-2006 16:22:12
 Re: Hobart handler 140 wire welder in reply to rodgernbama, 12-17-2006 17:32:18
ever tryed flux wire on rusty stuff? burns hotter and gets thru the junk on th metal
