Tool Talk Discussion Forum
air compressor turns clock or counterclock ways
baler46
12-10-2006 22:32:48
Hi
Just putting togeather and old air conpressor and wondering if there is a certain way the compressor need to turn for the oil to lube inside the pump better? Or does it not matter. Thanks
Compressor pully..John,PA
12-11-2006 06:10:32
 Re: air compressor turns clock or counterclock wa in reply to baler46, 12-10-2006 22:32:48
Will not really matter. However the drive pulley usually is designed to PUSH air over the compressor to help keep the compressor COOL.
Actually the pulley is called the "FLYWHEEL"' HTH, John,PA
PaulW_NJ
12-11-2006 04:52:35
Good tip! I"m about to replace the motor on an old compressor a buddy gave me (without motor) and I was wondering how to know the motor direction. Thanks!
Vern-MI
12-11-2006 02:56:48
The drive pulley will probably have blades built into the spokes. These blades, or fan if you will, should blow air across the compressor. So determine the direction of rotation from the blade angle.
Bus Driver
12-11-2006 05:00:42
 Re: air compressor turns clock or counterclock wa in reply to Vern-MI, 12-11-2006 02:56:48
Vern is correct. Actually, the compressor would pump OK turning either direction, but would not last long if turning the wrong direction. Many of them use splash lubrication and the dipper on the connecting rod would not get oil if going in the wrong direction.
