Everybody's giving you good sound advice.. I can't add much to it.. but here's a link to a place with a lot of good chainsaw & chain sharpening information. They are a big logging supply dealership out of Washington State. Browse around.. nice descriptions of chain types, filing techinques etc. Link I might as well toss in the rest of my 2cts... which pretty much matches what others have said. Your bar shouldn't get that hot. You're not getting lube to it, running the chain way too tight or something's really wrong with the grind on the chain. Hold the saw with the bar tip over a board, piece of cardboard etc... rev it up.. you should see some oil coming off the chain. Make sure you have a tip luber and keep your roller tip greased too. If your saw is producing sawdust, something is wrong with the way your chain is sharpened. You should see 'chips' coming out if cutting cross grain.. if ripping, you should get nice long curly shavings. A dull/bad chain will heat up... this probably explains why your bar getting so hot. A properly sharpened chain working on clean, green hardwood should cut a pickup load of firewood before needing a touchup. Dirt, rocks etc will kill the chain much sooner that that. By the way, what kind of wood are you cutting, and what condition is it in ? -- bb
