Tool Talk Discussion Forum
glue for plastic
jdjack
12-09-2006 17:49:41
My son broke a peg in our frig. What is a good glue for plastic?
Vern-MI
12-12-2006 13:57:29
 Re: glue for plastic in reply to jdjack, 12-09-2006 17:49:41
Just talked with my nephew who owns a hobby store featuring model planes and he recommended Plastiweld made by Plastruct. It is a liquid plastic welder designed to melt the two plastic pieces together creating a plastic to plastic bond.
Bob
12-09-2006 21:29:42
Likely, the peg can be easily replaced, a much better "fix" than gluing it, and having the shelf fall out sometime later, when the glue fails!
led
12-09-2006 21:11:33
Try ; www. this to that
Led
Davis in SC
12-09-2006 21:00:34
I think most fridge liners are ABS... Model car glue should work fine.. ABS is very similar to Polystyrene..
Vern-MI
12-10-2006 06:21:09
 Re: glue for plastic in reply to Davis in SC, 12-09-2006 21:00:34
Testers model glue is the best for polystyrene as it softens and fuses the welded component boundaries back into each other. Any other form of adhesive relies on a keying effect to make the bond. Use the right one the firsat time or the contamination from the first attempt may destroy any chance to use a correct adhesive later.
Eddie in MI
12-09-2006 19:10:05
I've had good luck with both Gorilla Glue and Seal All.
BigMarv1085
12-10-2006 06:27:04
 Re: glue for plastic in reply to Eddie in MI, 12-09-2006 19:10:05
Loctite super glue.
