Tool Talk Discussion Forum
'New' 1986 Ford F250
Slowpoke
12-09-2006 12:08:52
Just bought an '86 F250 XLT extended cab with a 460 engine. Other than a friend of the previous owner taping a Helicoil thread in one mounting hole in the water outlet neck and trying the same in the bolt hole in the head and breaking off the tap ( which is still there), it could be a good truck. Except that both doors have extreme play in the hinges. Do I need to replace the complete hinge or can I remove the permanent non-removeable hinge pins and replace them with aftermarket pins from the local auto supply?
jhill52
12-09-2006 12:16:22
 Re: 'New' 1986 Ford F250 in reply to Slowpoke, 12-09-2006 12:08:52
I had an 86 F-150 and the drivers side door got loose. I bought a kit with new bushings and pins and it fixed the problem.
Jerry
Slowpoke
12-09-2006 12:21:11
 Re: 'New' 1986 Ford F250 in reply to jhill52, 12-09-2006 12:16:22
Were your pins permanent? Mine appear to be installed from the bottom and riveted on the top.
jhill52
12-09-2006 12:47:06
 Re: 'New' 1986 Ford F250 in reply to Slowpoke, 12-09-2006 12:21:11
Yes my pins were permanent. I grund off the head with a small grinder and drove the old pins out. New pins came with the kit. Was pretty easy.
