Kwikway valve grinder
Jack
04-06-2001 20:39:16
Does anyone know where I can get a 3" depressed center grinding wheel with a 1.1" center hole to fit the stem grinding side of an old Kwikway valve grinding machine (#17141). Thanks, Jack
Al English
04-07-2001 07:34:13
 Re: Kwikway valve grinder in reply to Jack, 04-06-2001 20:39:16
Hi Jack, If there is a supplier of industrial machining supplies in your area they will either have the stone, or will have access to it. You will need to know the size, shape, mounting requirements, RPM limits, type of stone, and abrasive type and grit size. As far as I know Kwik-Way is still in business. If they are still around I'm sure they won't be as cheap as buying from an industrial supplier. But on the other hand you're sure to get the correct type and grit of wheel from them. Good luck...Al English
wrenchman
04-07-2001 02:11:40
try NAPA,they seem to carry a lot of stuff other than vehicle parts.they carry many repair equipt.parts.MSC also has a large selection of grinding wheels,along with other stuff.
Pollack Pete
04-07-2001 05:19:10
 Re: Re: Kwikway valve grinder in reply to wrenchman, 04-07-2001 02:11:40
I agree with Wrenchman.Try the NAPA tool and equipment catalog.I bought a wheel for my Sioux valve grinder recently.They also have the grinding wheels for the valve seats.Good luck.Pollack Pete
Kirk
04-07-2001 07:18:17
 Re: Re: Re: Kwikway valve grinder in reply to Pollack Pete, 04-07-2001 05:19:10
Try www.goodson.com
