Tool Talk Discussion Forum
Table saw wheels needed
Gary Schafer
12-08-2006 16:33:37
I have a sears 10" table saw that I need some wheels for so I can move it around. You can't get them from sears anymore. Anyone have any? Or any ideas how to make something that can be easily raised and lowered to move/work?
Thanks
Gary
ZacsDad
12-12-2006 08:46:36
 Re: Table saw wheels needed in reply to Gary Schafer, 12-08-2006 16:33:37
Sears sells a pretty good mobile base that is sturdy and very adjustable. It usually sells for about $100 but is often on sale for $65 - $70. I have one sitting under my bandsaw, and my Delta Model 10 Contractor"s Table Saw. Wheels are small but work well on concrete.
mwkellner
12-11-2006 11:45:16
Gary, I have an older Sears 10" Table Saw and I found that a rigid (home depot) set of wheels that lift it up and down fits perfectly. It was about $90 if I remember right. It works great. I also have the old wheels that I don't need any more for way less than $90 if you wnat them. Let me know.
Gary Schafer
12-12-2006 10:43:33
 Re: Table saw wheels needed in reply to mwkellner, 12-11-2006 11:45:16
Hi mwKelner, I am interested in the wheels that you have. I sent you an email don't know if you got it?
Thanks
Gary
Chester
12-10-2006 09:20:34
Or, you could make something similar to this arrangement. Two wheels swivel and the other two are on a pivoting axle. This removes the need to raise/lower any wheels and makes everything stable and self levelling.
don t.-9n180179
12-10-2006 00:41:42
How about 2 rollers on the outside vertical legs of your support table. Grab the extention arms and move it like a hand truck.
HTH....have fun....don t. .....
Rod (NH)
12-08-2006 19:04:19
Hi Gary,
Delta makes a universal mobile power tool platform that you add wooden connectors to in order to customize it for the size of your tool. I've used them under both a 12" table saw and a 10" radial saw. They work very well. Much better than the old sears wheels that I used to have on the radial. You can buy them on-line here. I got mine at a local woodworking supply store.
third party image Rod
ken B
12-11-2006 06:25:59
 Re: Table saw wheels needed in reply to Rod (NH), 12-08-2006 19:04:19
I have the Delta under my table saw works great
Tom in Central Pa
12-08-2006 17:12:24
I use old cookstove rollers. They are triangle shape, about 4-1/2" across, cast, with a dropped center, and a caster-wheel on each point. They come in sets of 4. Usually available at antique shops, second-hand stores,and flea markets. Usually under $10 a set. Set one on the floor, tip/lift your saw, and push it under the leg with your foot, then do the others. Look carefully before you buy, I"ve seen some damaged ones. Best ones have ball-bearings in the caster swivel, cheaper ones have small discs instead of ball-bearings.
Slowpoke
12-10-2006 11:40:51
 Re: Table saw wheels needed in reply to Tom in Central Pa, 12-08-2006 17:12:24
I think the small three wheel dolly you describe is probably available at hardware stores, Harbor Freight, Home Depot, etc. But I also think that the wheels are a bit to small for any kind if rough surface movement.
