Tool Talk Discussion Forum
Shapening a knife
Ollie also
12-08-2006 16:33:23
I have a whetstone and wheel grinder. I like the whetstone better than the wheel grinder.It is water cooled. Shall the knife blade be sharpened away from the stone or in to the stone? Hope this is understandable. Thanks for all replys.
Cliff(VA)
12-11-2006 05:53:32
 Re: Shapening a knife in reply to Ollie also, 12-08-2006 16:33:23
I find that a motorized grinder (even a wet one) takes off too much metal for a knife. There really is not much there to begin with and it is easy to work off a minimum amount to provide a sharp edge on a stone.
I use a set of diamond stones, one of my buddies uses Japanease water stones, and I know of a guy who uses aluminum oxide sandpaper backed by a glass sheet. All of these techniques can put an edge on a knife that will slice through wood like it was butter. The important part is to use a series of graduated stones, starting with a medium grit and working up to the finest grit you can find. Cut into the stone a few strokes and then flip the knife and do the other side the same number. The back of the knife should be raised enough to fit a dime. The knife will likely form a wire edge and then work it off as you go.
Then for a really fine edge strop the knife (working AWAY from the edge) for a few strokes on a leather strop that has been charged with chromium-oxide (this is why barber's strops are green). Just one or two strokes, too many will round over your edge.
Be careful, a truly sharp knife will cut through flesh without your feeling it. I no longer sharpen my pocket knife as sharp as my woodworking tools, I got tired of the cuts on my fingers where I lightly touched it.
Hope this helps,
Cliff (VA)
Matt Smith
12-09-2006 13:52:49
How a knife is sharpened depends on how the blade was ground. A flat ground blade needs to be sharpened by pushing the blade against the whetstone. A hollow ground knife needs to be drug against the whetstone. It then needs to be stropped against a piece of leather. I use the backside of my belt. I can get just about any knife to shave hair, but my best knife will shave ink off newspaper.
MarkB_MI
12-09-2006 05:53:01
Sharpening the blade "backwards" (edge away from the stone) will tend to form a "wire" edge. A wire edge is a thin edge that tends to break off the blade.
For my serious sharpening chores, I use a set of japanese water stones. These are fairly soft, very fine stones that will put an edge on a blade like nothing else.
John T
12-08-2006 19:30:27
Ollie, you sharpen it INTO the stone like youre trying to shave a thin slice of the stone off DO NOT draw away from the edge. To get mine razor sharp where they will dry shave arm hair up or down, I start with a coarse stone,,,,, ,then a fine stone,,,,, then an arkansas hard,,,,, ,,,then I finish with those ceramic crock sticks.
John T
msb
12-08-2006 19:26:06
Stop by a sporting goods store and pick up a Rapala fillet knife.Used to be they had a good description on the package of how best to sharpen a knife.Don't buy the knife.Only read the instructions.Thats how I learned.
old
12-08-2006 17:40:05
I sharpen my knifes by hand with a wet stone. I always sort of cut into the stone to sharpen them and when done I loose hair off my arm or I'm not done. Hope that explains it
