Tool Talk Discussion Forum
need help reading Dodge VIN
Rich Iowa
12-08-2006 14:10:15
I have a 2003 Dodge 2500 and I'm having a hard time figuring out what size gears are in the axles. The truck has the towing package, Cummins diesel, 6spd manual tranny, and 4wd. The VIN# is; 3D7KU26CX3G720647, I've heard the gear ratio is somewhere in the VIN# but I don't know where. Thanks for any help.
Hobo,NC
12-08-2006 19:09:25
 Re: need help reading Dodge VIN in reply to Rich Iowa, 12-08-2006 14:10:15
The parts dept at yer local Chrysler dealer kin tell ya the gear installed in it when new from the vin.
Rich Iowa
12-09-2006 05:34:47
 Re: need help reading Dodge VIN in reply to Hobo,NC, 12-08-2006 19:09:25
Thanks for the help guys. the differential doesn't have a tag, I looked there first. At 70mph the engine is running at 2000rpm even. I was thinking if I could find some shorter gears, I might be able to squeeze anothe mile or two out of each gallon. I guess I'll have to swing into the local Dodge dealership and have a chat with them. Thanks again.
RustyFarmall
12-09-2006 13:21:55
 Re: need help reading Dodge VIN in reply to Rich Iowa, 12-09-2006 05:34:47
Actually, you are wanting longer gears, sometimes called taller gears. It will give your truck longer legs, so it can run faster, but it won't be as good when asked to heavy "grunt" work, such as pulling a travel trailer. Taller gears will make the engine work harder, probably won't improve fuel milage, and might make it worse.
Tim Casbolt
12-09-2006 12:00:05
That sounds like 3.73's. Nothing lower numerically is available yet, although the aftermarket is supposedly working on it. Personally, I think you could buy a lot of diesel fuel with the money you'd need to change gears. You know they're going to soak ya good for gears that fit an AAM. And don't forget the drop in performance that comes with it.
Charles (in GA)
12-08-2006 18:53:31
Possibly on a tag on the differential? I know Fords and Jeeps are/were done that way, not sure about Chrysler products.
Charles
Davis In SC
12-08-2006 19:00:28
 Re: need help reading Dodge VIN in reply to Charles (in GA), 12-08-2006 18:53:31
Wow, 2 posts at the same time, down to the second!! & both with the same info.. Us Southern boys have got things figured out... :^)
Davis In SC
12-08-2006 18:53:04
There may be a metal tag attached, or the Ratio stamped on the diff. cover(s) My 2001 3500 also has the HO Cummins & the 6-speed. All the sales lit & specs state that it only came in 4.10, but mine is 3.52, according to what is stamped on the covers.
Tim Casbolt
12-08-2006 15:01:21
It's probably in the glove box, although sometimes is only specifies if it has the optional 4.10 ratio. If it says nothing, it would be the standard 3.73 ratio. Those were the only two possibilities. What are your rpm's at 60 mph?
CNKS
12-08-2006 14:26:42
I doubt if it's in the VIN, engine size, yes. Gear ratios usually have a code, sometimes in the glove box. You need a chart that deciphers the codes, usually in the service manual. Your dealer should be able to help you. You can crawl under it (block it up good) and count the driveshaft revolutions as you turn the wheel.
