Tool Talk Discussion Forum
12volts 2 24
ross in ns
12-06-2006 15:53:59
hi all wondering what the way to hook up 2 12 volt batterys to get 24 at starter my machine has 24 volt start and has ben very slow to turn i found out it is only getting 12 volts poor wireing job previuos thanks
old
12-06-2006 19:49:15
 Re: 12volts 2 24 in reply to ross in ns, 12-06-2006 15:53:59
A lot depends on the machine as to how its wired. Some have a 12 volt chargeing system but use 24 volts to spin the starter and depending on what you have it makes a big differance as to how its wired up. Need more ifno to be able to take a good guess on this one
glenab11
12-06-2006 16:03:04
Starter main terminal to positive of one battery, negative of that battery to positive of second battery. Negative of second battery to ground. Assume negative ground.... if positive ground do opposite
ldj1002
12-06-2006 16:27:08
 Re: 12volts 2 24 in reply to glenab11, 12-06-2006 16:03:04
I assume you have a 24V alternator. If not you won't keep those batteries charged. You didn't say what your machine is. Back in the 80's I saw several conversions from gas to diesel and they wouldn't start good. Sooo they got 24v starter and 2 batteries. They thought since it was 2 12v batteries that the 12 alternator would keep them charged.
