Tool Talk Discussion Forum
Motor Dies on splitter
Tnau
12-03-2006 18:42:07
Need help guys. I have a 5.5 Briggs on my home made splitter. It splits most stuff but when it gets loaded it kills the motor. Also, kills the motor if I"m not careful when I retract the cylinder. Anyone had this problem? I don"t have a clue what size pump I have.
Thanks for looking
Terry
Piedmont, AL
Oldmax
12-05-2006 06:15:51
 Re: Motor Dies on splitter in reply to Tnau, 12-03-2006 18:42:07
Your pump is to large get a small two stage pump from northern tool will solve problem .
Charles (in GA)
12-03-2006 19:47:28
Check out the link for relief valves.
Charles
Charles (in GA)
12-03-2006 19:49:04
 Re: Motor Dies on splitter in reply to Charles (in GA), 12-03-2006 19:47:28
Sorry, link didn't take first time.
Charles
tnau664
12-04-2006 16:05:27
 Re: Motor Dies on splitter in reply to Charles (in GA), 12-03-2006 19:49:04
Thanks for the response. Where would this valve go? I have a standard block like Northerns 3000 series.
Terry
Gerald J.
12-04-2006 22:46:37
 Re: Motor Dies on splitter in reply to tnau664, 12-04-2006 16:05:27
It connects from the pressure to the return.
Gerald J.
Gerald J.
12-03-2006 18:48:55
You don't have a working pressure relief valve to protect the pump and motor when the cylinder gets to the end. That may be made worse by using an unknown pump that has too large a capacity.
Gerald J.
