Tool Talk Discussion Forum
medical use for a tool magnet........
phillip d
12-02-2006 17:25:13
sure did a good job removing a metal splinter from my eye this afternoon lol.I wonder how many out there has done this before and knew what the body of the message was before they even looked lol.memo to self,next time WEAR GOGGLES WHEN GRINDING DOUGH HEAD lol have a good one,phill
NEsota
12-03-2006 21:58:36
 Re: medical use for a tool magnet........ in reply to phillip d, 12-02-2006 17:25:13
An eye surgeon explained to me that there are times when an injured eye is removed even though the symptoms indicate that the probability of the eye being salvaged are better than 50-50. The reason for this is that with a problem in one eye, the brain may shut down all vision in both eyes, rendering the person completely blind. The shut down is a defense mechanism the body has, in order that people not go insane because of conflicted vision. Retaining vision in one eye is very preferable to blindness.
Bud in NC
12-03-2006 16:48:41
Looks like I'm kinda late getting here - I used to be a welder and I've had stuff removed from my left eye - I was REAL lucky - not bad except for being SCARED SH*TLESS!!! It took hemostats ("R-clips!") to PULL the piece outta my eye! Sounds like your's was not a major problem so hopefully it'll be OK.
Now for the rest of the story - The way it was explained to me, one of the REAL dangers is your eye "leaking"...and if you loose about any the fluid in your eye due to something piercing ALL the "eye walls" yer eyeball will "de-flate" - and then yer SOL! And the fluid in your eye doesn't "grow back". If it wasn't REAL minor you might want to get it checked! Take care and good luck!
phillip d
12-03-2006 10:28:20
thank you all for the helpful advice.So far so good as far as the eye goes,for next time like the advertisements say "safety doesn't hurt",phill
MarkB_MI
12-03-2006 08:31:31
This is why it's doubly important to wear eye protection when working with non-ferrous metals that can't be removed with magnets.
Mattlt
12-03-2006 06:54:27
On a related note. If you've ever had an MRI, they will ask you if you do metal grinding or cutting. If you do, you'll need to have an eye exam first. The magnetic field from the MRI is enough to drag embedded pieces of metal around the eye, possibly causing more damage.
Of course it's a CYA liability thing to have you go to the eye doc first.
jeffcat
12-03-2006 09:37:27
 Re: medical use for a tool magnet........ in reply to Mattlt, 12-03-2006 06:54:27
Yup- not that long ago someone had left a small Ox cylinder near an MRI unit and when they powered it up the tank flew. I don't remember if someone got killed. If I remember it was on Paul Harvey. Going on about strong magnets; you can get some of those rare earth jobs on Ebay. I have a couple of them and they are one inch square and one half thick. DON'T put them together! I got one H--- of a mean blood blister! Boy can they give you such a pinch.Jeffcat
Stan in Oly, WA
12-03-2006 10:08:18
 Re: medical use for a tool magnet........ in reply to jeffcat, 12-03-2006 09:37:27
Hi jeffcat,
It was a rare earth magnet I used to get the fleck of steel out of my eye. Like you, I also found out that it isn't a good idea to bring two of those magnets too close together with part of a finger still between them. The other thing about them is that although they're surprisingly powerful, they're not mechanically strong themselves. One of mine shattered from letting two of them slam together.
Have you discovered anything useful to do with them? I haven't, now that I've learned that removing steel from eyeballs is a risky deal.
All the best, Stan
Hey..John,PA
12-05-2006 09:59:19
 Re: medical use for a tool magnet........ in reply to Stan in Oly, WA, 12-03-2006 10:08:18
Stan,
Believe this? I have 4 MRI magnets stuck on to my front bumper of my Ford van. I have increased my fuel mileage by 50% whenever I get close to an 18wheeler when goi'n down I81 to Florida.
Stan in Oly, WA
12-05-2006 13:13:45
 Re: medical use for a tool magnet........ in reply to Hey..John,PA, 12-05-2006 09:59:19
50% seems high to me with only 4 magnets.
jeffcat
12-04-2006 09:50:21
Hey Stan, They are a GREAT way to magnetize your tools. Draw the screw driver across the magnet a couple of times and it will be so strong it will hang from the bottom of an iron pipe! IF you need to retrieve something put a long iron extension down the hole and then stick the magnet on YOUR end. It will pick up the objet down in the hole. Just remember that they will blast your credit card from about five miles away! Don't get your old wind up watch neer them either. They hold metal together for welding too. The one thing you never want to do is get them hot .NEVER NEVER They loose their power if they get hot and now you have a tiny paper weight. Also keep them on a thin metal plate or surface like your old beer fridge. This keeps them at full power. The key word is THIN so you can pull them off. They are a great tool and you shur as shootin want to be carefull not to use them as a toy! Jeffcat
Hey..John,PA
12-05-2006 10:23:37
 Re: medical use for a tool magnet........ in reply to jeffcat , 12-04-2006 09:50:21
So that is why I get called from time to time to consider doin' refrig. service on the local hospital's MRI machine. I keep trying to tell them to call the outfit that sold it to them. John,PA
dr.sportster
12-03-2006 06:28:49
Got this off a site where they were talking about really bad shop accidents:"You can eat with false teeth,You can walk on a wooden leg,But you cant see out of a glass eye." A trip to the doc might be warranted anyway[an eye specialist].At least make sure it doesnt get infected.Beleive me I hate doctors and If I could fix my teeth with a Dremmel tool,Id do it.I had a piece of brass get under the skin of the eye when I was a kid and it took an eye surgeon to get it out.Sometimes there is more to it.If you have punctured into the cornea you at least need an eye cream.Im not trying to get you all depressed just trying to help.You may know best but if you see any additional redness go right to the emergency room.
Vern-MI
12-03-2006 04:46:22
Got a metal sliver in my eye from blowing off a work bench. Magnet would not get it but Q-tip snagged it so it could be pulled out. Then they had to shave my eye because of the rusty spot the metal fragment left. Doctor used a knife and said to keep my eye open when he was trying to shave it. That was not very easily done.
Forgot my password
12-03-2006 22:49:02
 Re: medical use for a tool magnet........ in reply to Vern-MI, 12-03-2006 04:46:22
Another way like the Q-tip is to use the end of a paper match torn from the book.
Jimmy King
12-02-2006 18:42:37
Now take care of that eye, I have a Brother in Law that lost an eye from that very same thing when it got infected, thought for a while he was going to lose both of them.
Patchfarmer
12-02-2006 19:50:47
 Re: medical use for a tool magnet........ in reply to Jimmy King, 12-02-2006 18:42:37
Thats a pretty big needle that they use to dig something out of your eye.
Stan in Oly, WA
12-02-2006 18:20:15
Hi Phillip,
I have done it and I did know (or at least had a pretty good guess which turned out to be correct) what the message was about. Here's something I'll bet you didn't know, though. At a shop safety meeting a few months ago, when I mentioned that I had used a magnet to remove a steel splinter from my eye I was told that it was a dangerous thing to do. If the splinter goes in at an angle, the magnet won't necessarily pull it out end first. Be that as it may, it immediately felt a whole lot better to have that metal out of my eye and there were no further problems. I'd probably do the same thing again.
All the best, Stan
BigMarv1085
12-02-2006 19:48:54
 Re: medical use for a tool magnet........ in reply to Stan in Oly, WA, 12-02-2006 18:20:15
There is nothing like having your head strapped in a vise and having a needle cranked up to your eye to pluck out a metal sliver.
