Tool Talk Discussion Forum
TIE DOWN
Dennis in NC
11-30-2006 05:32:59
I HAVE A LARGE CAMPER IN THE BACK YARD,I USE AS A REC ROOM WHEN THE GRANDS COME . I WOULD LIKE TO TIE IT DOWN . I PICKED UP 6 SCREW TYPE STEEL ANCHERS .? WHAT DO I USE TO SCREW THEM INTO THE GROUND. NC-CLAY SOIL
Bud in NC
11-30-2006 17:22:19
 Re: TIE DOWN in reply to Dennis in NC, 11-30-2006 05:32:59
Being kinda familure with the "not kilned yet bricks" we call "dirt" here....It ain't good news...
Coupla options - dig a hole (SOMEhow!)- on an angle might work better, add the hold down and enough concrete to fill the hole - about a bag and a half per hole or so should do it - or what ever it takes to fill the hole. Rocks and old bricks make good filler.
Yer PHDs will dig the hole....eventually! Check the tips often - gotta hammer them back straight once in a while due to the rocks you'll hit.
Don't think that adding water will help - it'll just make the clay too slick to stand up on and it'll stick to your tools even worse!
Any chance you have access to a helpful neighbor with a small tractor and an auger who's willing to help? Dig the holes with that. There's other possibilities there but unless the guy with the tractor is good at fab work & shade tree engineering, that'd be best left alone!
Good luck - what part of NC are you in? I'm near Lincolnton - just south of Hickory.
Dennis in NC
11-30-2006 19:18:54
 Re: TIE DOWN in reply to Bud in NC, 11-30-2006 17:22:19
221 S . HARRIS / RUTHERFORD COUNTY . I GESS SHELBY IS GOING TO THE BIG DANCE .HS FOOTBALL . YOU GUYS GOT ANY OLD IRON ROUND THEIR . I USE TO BE ALL RED THEN I WENT OUT WEST TO PORTLAND AND PICKED UP A 36 JD BR. STILL HAVE 6 RED , 2 CUBS -1 A ,1-B ,230,F30 . BEEN LOOKING FOR A TRI FRONT C SO I CAN HAVE MY ABC'S IN ODER.
ScottP
11-30-2006 09:40:26
I met a guy who set up mobil homes in trailer parks, he had a hand held electric pipe threader with a custom adapter for putting them in. Man was that a slick set up.
Scott
Rustyfarmall
11-30-2006 06:06:20
It is a problem sometimes. The first thought is to find the biggest pry bar you have that will fit through the eye of the anchor, but if the ground is really hard, you will only succeed in twisting the screw anchor. Your best option is to probably get out the post hole jobbers and dig a hole.
