Hi, bet the winch isn't very well bonded to the trailer frame. However, better electrical bonding between the winch and the trailer frame won't necessarily solve the problem, and in fact may make it worse by reducing the resistance through the unintended frame/hitch path. The return path through the trailer frame, hitch, & pickup frame would have a lot less resistance than the path through the negative jumper cable, particularly if the jumper clamps weren't making super good contact. Therefore, most of the return current (several hundred amperes if you have a reasonable size winch under heavy load) flowed back through the winch cable to the trailer frame through the hitch ball to the pickup frame to the negative vehicle battery cable. Even if the winch wasn't running, its a good bet that most of the current flowing into the discharged trailer battery was also going back through this path. Bet the winch cable burned in two where it rubbed on the trailer frame, or on the fairlead where it came out of the winch itself. A couple solutions...1) get a bigger winch battery so you don't run it down as quickly & therefore don't have to jump it, 2)as others have said, disconnect the trailer from the tow vehicle, or 3) disconnect the tow vehicle battery negative lead from the tow vehicle before using it to jump the trailer battery (don't do this with the engine running!). Be aware that if you disconnect the hitch, you also need to disconnect the connector for the lights & brakes, otherwise all the winch current will try to return via the ground wire in the trailer connect & you'll melt the whole thing. Good luck, Keith
