Tool Talk Discussion Forum
Wet stone question
wallie wallie
11-27-2006 16:46:35
Will a wetstone when wet freeze and break. I have a knife sharpener that is wet stone and it works great, but if I take the water out of the reserve tank will the water in the wetstone freeze and break? thanks for you response in advance.
Dave Sherburne NY
11-28-2006 10:17:26
 Re: Wet stone question in reply to wallie wallie, 11-27-2006 16:46:35
You should always take the water out of the resivoir when the stone is not being used because the part of the stone that is setting in water
will become softer and wear down faster when the stone is being used. Have you noticed how many stones aren't round anymore. An old old friend of
mine told me you could true it up again with a gas pipe whatever that is.
Lester G. Elwood
11-28-2006 05:05:06
This is for NE IA Dave. If you are interested making a whetstone, one source you might try is the Foxfire series of books that came out in the late 60s or early 70s I believe. They had a lot of interesting info in them along with ways to make things from the past.Just a thought. Good Luck Lester
NE IA Dave
11-28-2006 16:30:53
 Re: Wet stone question in reply to Lester G. Elwood, 11-28-2006 05:05:06
Lester, I will certinaly give it a try this winter when the bad weather keeps me closer to home. It is nice to live in a social group such as this board where complete strangers offer their help. I certianly appreciate your help, this is a darn good bunch of guys. NE IA Dave
NE IA Dave
11-27-2006 20:29:14
I will throw in my opinion only with no intention of offending others opinions. In the cold climate in our area they for the most part have big chips out of them. For years I always thought that Mr. farmer used it in one locked position and wore a flat spot in it. Just like a hand held stone gets a low spot after years of hard use. Seems like pretty unreasonable thinking after it was explained to me. The stones usualy had a cup or half moon shaped ordeal under the stone to hold the water. If it sat out in the weather for years,(after retirment) the cup was usualy full when winter came so the water soaked stone would freeze and next year freeze again. Thus the stone would break away and make a small flat spot. For some reason those stones catch my intrest, and when I say stone, that is probably not as I first assumed either. A older gentelman told me he found in a very very old book how they made the stone. Yes --he claimed-- it involved ashes, clay dirt, tallow,and fired lime. He has tried to remember the book or where he saw the formula, but has not yet found it, and he was not sure of any of the products used to make the stone. I tried many times in the last ten years to find the way to make new stones, yet no idea yet. So anyone who has a idea let me know if you would be so kind. I have figured that you can buy stones, that are fine on one side and in a perfect line the other side is rougher, making the guys idea of pouring the stone more likley. Therefore, if you think how concrete block absorb water like a dry camel, when it freezes the blocks go south pretty fast in a high moisture inviroment. So therefore probably in the very slightest form--- perhaps-- your stone will last longer if kept dry. Just my way of looking at the situation. Perhaps not the correct way however. NE IA Dave
Rustyj14
11-27-2006 18:36:51
My old Grampaw lived on a farm for some years, and he had a Whetstone, the kind on a bench ya sat on and cranked it with yer feet. It had a little funnel on a hook, into which ya poured a quart of water, and it dripped down thru a little hole onto the grinding wheel. Now, i know he used it frequently, and in 20 years it never froze and cracked or broke. I don't think the water penetrated very far into the stone, just sort of laid on the face, to keep the tool cool. As for the kind ya hold in yer hand, just keep it in the barn or house, and it will never freeze, although i don't think it will, anyway! Unless you leave it soaking in water for a long time, maybe. Probably the ones you saw broken got run into by some machine and knocked over, onto a hard surface.
4010guy
11-27-2006 16:50:58
Im thinking yes as i have seen a lot of old wet stones laying in junk piles and they were ALL broke.
Stan in Oly, WA
11-27-2006 18:27:28
 Re: Wet stone question in reply to 4010guy, 11-27-2006 16:50:58
Hi 4010guy,
What kind of reasoning is that? That only proves that people throw their broken wet stones (actually whetstones) in junk piles. Or was that some dry country humor that I'm now the butt of?
All the best, Stan
4010guy
11-27-2006 18:47:28
 Re: Wet stone question in reply to Stan in Oly, WA, 11-27-2006 18:27:28
Hi and good day,Achaley no it realy wasent ment as humor or to smartoff,,,Its just that i have seen a lot of that sort of stuff from days gone by around here that has been set out back and i have noticed that they are ALWAYS broken and that they lay so that peaces fit together so im assuming it was the rain and snow melt along with the freezeing temps that got to them...And sorry about the spellen----Im just that way!
Slowpoke
12-01-2006 00:23:11
 Re: Wet stone question in reply to 4010guy, 11-27-2006 18:47:28
With today's adhesives one might be able to put the pieces back together and use the stone again. There was a program on I think the History channel where two pieces of sheet steel were joined with adhesive using a lap joint. It was put under tension and the steel pulled apart in an area away from the joint.
Stan in Oly, WA
11-27-2006 19:18:19
Hi,
I wasn't criticizing your spelling. You weren't the one who spelled it wet stone instead of whetstone in the first place. Besides, I don't care how people spell things. Once in awhile I'll point out something like that because I think it's interesting and wonder if other people might think so too. That's all.
I really wondered if you were making a play on words by answering a question about the blade sharpening things (whetstones) with an observation about wet rocks. Whetstones/wet stones. That's what happens when I drink too much coffee late in the day---my mind goes really fast without going really well.
All the best, Stan
4010guy
11-27-2006 19:26:06
 Re: Wet stone question in reply to Stan in Oly, WA, 11-27-2006 19:18:19
No problom stan,,,good night now.Im otta here
