Tool Talk Discussion Forum
McCulloch chain saw question
Kmiller
11-26-2006 16:28:12
I asked you guys about the primer bulb on this same saw last year and you fixed me up so now I'm back again. The saw is a McCulloch 3516, my dad has been using it but now it's not oiling. I was there this week and replaced all the fuel lines and a cracked oil line (tank to oil pump) but it's still not oiling. Does the oil pump go out if it sucks air? I ran it for about 5 mins to see if it would start oiling after I replaced the oil line, should it take longer than that to start pumping oil? Do I need to prime the pump?
Any ideas on how to make it start oiling?
Thanks,
Kerry
Victoria, TX
2x4
11-27-2006 22:27:02
 Re: McCulloch chain saw question in reply to Kmiller, 11-26-2006 16:28:12
no need to prime pump. Sucking air will not make oil pump go out. Should pump oil in less than 30 seconds. Make sure the tank is clean, then Pull oil filter part way off & run it. If no oil, your pump gears are shot, most likely. Probably plastic & they just wear out.
in sticks
11-26-2006 17:49:31
is there a filter on the oil line in the tank?
Kmiller
11-26-2006 18:22:13
 Re: McCulloch chain saw question in reply to in sticks, 11-26-2006 17:49:31
Yes, there is a filter in the tank, I changed the oil line (it was broken) and put the filter on the new hose. The filter isn't plugged, I blew through it.
