Tool Talk Discussion Forum
Trailer Suggestions Please!
Mark (PA)
11-26-2006 10:46:10
Hello all, Looking to get some suggestions on Trailers here (hope this is the right place to post it). I currently have a 6" x 12" Utility Trailer, Single axle, nothing fancy. I am looking to upgrade this for a few reasons but having a dandy of a time deciding the best route.
I want a dual axle for alot of reasons, Stability and weight limit mainly. I haul hay that I sell and right now I can only get 70 bales MAX on this trialer and obviously most customers wish I could bring 100 or more. I also have some farm equipment that I would like to be able to haul to shows etc from time to time but I can"t do that as the weight limit on my trailer right now.
The tough part is what to get? Do I get another utility type that is 14" or 16" with rails or go for a flattop type so its easier to haul a hay rake for instance. NO rails to get in the way. A utility is nice to use for hay hauling with the rear gate whereas a flattop would have to be stacked really well and strapped down more I assume?
So hopefully folks out there and advise on which route they would take.
MY hauling vehicle is not your typical pickup either. I have a toyota 4runner. It is a V6 and I have a class III hitch on it but as mentioned it probably won"t haul as good as your F250 so to speak. I do not have trailer brakes setup on the vehicle so I would need to add that as well but brakes in my opinion are a MUST.
I almost think based on my vehicle a 14" would be the best for length. 16" maybe too much? Let me know what you all think here.
I guess I should add I don"t really want to break the bank but who does?
Thank you.
Mark (PA)
11-27-2006 17:12:09
 Re: Trailer Suggestions Please! in reply to Mark (PA), 11-26-2006 10:46:10
HI Guys. Thanks for the tips. I am thinking ahead because in 2 years I am already planning to buy a larger vehicle to tow. The 4runner is a 5000 tow limit. SO if I would get a larger trailer now I would have to keep the trailer loaded not so much maybe. Thanks for all the tips though. I have a good lead on a landscaper type trailer but overall it seems to me to make more sense to get a flat deck as most of you guys already know! Thanks again... Probably just keep looking for now.
wdTom
11-26-2006 16:44:19
A trailer with no side rails is a lot more flexible than with one with welded on side rails. You can always put sideboards on a flat bed trailer. Most have stake pockets welded on already. All you need is a few 2x4s and a sheet of plywood for each side. Rip the plywood into 2' wide strips, drywall screw it to the stakes and you have 2 high sideboards. If you want to be hauling equipment, tractors etc. look at the width. About 82 to 84 inches is about the max you can get between wheel wells on a trailer unless you get a deckover and they don't generally make them in a smaller (say 7000 lbs. gross) trailer. Get brakes on both axles. And as the others said, check your tow vehicle and see how much you can haul with it.
KEH
11-26-2006 15:28:23
Agree with the posts that said check on the towing capacity of the 4 runner.
Concerning flat top or trailers with rails on sides, I would get flat top. If I understand you right, the kind with rails you are referring to is commonly called a landscape trailer, designed to haul lawnmowers, etc. It does not have a strong frame, but depends on the rails to form a truss giving it good strength. One problem for you is that farm machinery would have to fit inside the rails but the main problem is that you have to lift the hay bales over the rails and they would have to fit inside the rails which might not always work out. Flat trailer would allow some overhang, but you have to fit them between the tires. In the past I have hauled a lot of squares and these are the problems I had.
Be sure and check the weight and hauling capacity of trailers you look at. Hope this helps.
KEH
jhill52
11-26-2006 11:53:24
Need to know towing capacity of 4runner. Should be in owners manual. Probably not more than 5000 lbs. That is your legal limit. A 14 ft 2 axle trailer probably weights 2000 lbs. 70 bales weighting 50 lbs is 3500 lbs so the trailer would weight 5500 lbs. You can't legally haul as much hay if my numbers are correct. Sure you could probably haul more but that is what is legal for you to haul.
Jerry
RustyFarmall
11-26-2006 11:23:16
The trailer you have now is probably all you would want behind a toyota 4runner. Before you start looking at bigger trailers, you need to get rid of that 4runner. It is not a vehicle that is suitable for towing anything larger than what you already have.
Maark
11-26-2006 10:59:27
I used to pull a 16' with a 4wd 4dr. blazer with a 4.3 vortec. Had trailer brakes hooked up. It pulled it very well. Just don't overload the trailer.
