Tool Talk Discussion Forum
Stereo Receiver Control Switches
Glenn FitzGeral
11-26-2006 06:27:15
I ahve a Kenwood 60 watts/channel stereo receiver I bought new about 25 years ago. Many of the switches (volume, balance, etc. apparently have dirt in them as it "crackles" through the speakers when I turn them. Short of replacing the switches, what is the best way to solve this problem...spraying them with compressed air, flushing them with ether...? It is a very good old unit. What do you recommend?
Thanks, Glenn F.
Stumpalump
11-26-2006 11:03:54
 Re: Stereo Receiver Control Switches in reply to Glenn FitzGerald, 11-26-2006 06:27:15
WD-40 works great on dirty pots. Save your money on fancy tuner cleaner unless you need it all the time. Spray it and work the switch back and forth till its quiet.
Gerald J.
11-26-2006 10:20:47
Caig Laboratories makes a couple products. DeoxIT for switches, and another for dial type controls (potentiometers). They work very well, but work best when applied sparingly to only the contacts. They don't work so well just sprayed because they can damage insulating materials. I think Antique Electronic Supply carries them.
Gerald J.
dr.sportster
11-26-2006 08:05:54
All my stereos are garage sale specials and I have a Kenwood also.I was told in Japan they use soap and water and compressed air to clean them.The trick when the swiches dont stay in is to jam a control screwdriver to hold them in place.Paid ten bucks for the receiver and three for a JVC turntable.I had still used 8 track players until about five years ago.The only speakers I ever got new were the Bose weatherproof.When I saw them in the store in the waterfall I had to have them.You dont even have to rob my house to steal my stereo its all on the back porch.If your that desperate you can have it.Got loads of spare speakers in the barn.The new ones arent very heavy but the older stereos weight alot[I like that]I can blast bagpipe music for miles.{im not too sure about the soap and water cleaning thing}
Bob - MI
11-26-2006 06:43:00
You may want to try some TV tuner cleaner. This is probably getting harder to find now days but it is essentially an electrical contact cleaner. It comes in an aerosol can that you can spray into the "pot" while you turn the dial back and forth. Last can I got was at Lowe"s and it was about $6.00.
Only other thing I can think of is to search out an old TV repair shop that has been around a while. The folks there would have repaired things like this in the past.
I can relate here, I had an old Pioneer SX-1010 100w/channel reciever that I paid $500 for in 1975. Great unit but it had a bad output circuit in it that had a bad habilt of blowing transistors. I had it fixed twice at about $200 per episode and I finally threw it away.
Coloken
11-26-2006 06:37:37
They used to sell what they called "tuner cleaner" used for the contacts in the old rotary tuners. Spray can. Never worked all that good..kind of made the tuners adicted to it. Try just operating them a lot, may be they will clean up.
RJ-AZ
11-26-2006 06:36:18
Ether works fair but I used Electrical Contact Cleaner that I got at my NAPA store.
