Tool Talk Discussion Forum
broke off drive in zerk fitting
bil b va
11-25-2006 14:41:37
i have a couple of broke off 3/16 drive in zerk fittings i need to replace . whats the best procedure ? drill out ? i have the part diassembled . can i just drive them on through ? don't want to damage the hole and not be able to install new ones .
vally farm
11-26-2006 07:04:54
 Re: broke off drive in zerk fitting in reply to bil b va, 11-25-2006 14:41:37
If you can find reverse twist drill bits, use them to grill out for the easy-out. 99% of the time they will back out what you are working on, be it a bolt, stud, grease zerk, etc. Mike
Charles (in GA)
11-25-2006 20:19:23
I have to remove these things at work ocassionally, commonly used in airplane landing gears, where they cannot thread the hole, as the threads would cause a stress riser and a crack would form.
Drive in fittings are aluminum and barbed. No kind of ezz-out will get them out, there are no threads to back them out of. If the part is steel and is open all the way thru, take a punch and drive it thru, th aluminum fitting will not hurt it. If it is a blind hole, use a sheet metal screw and thread into the remains of it and use the screw to pull it out. Do not hit the new one with a hammer, it will ding the head of it and the grease gun won't seal on it and you'll have grease everywhere. Use a 1/4 drive deep socket that will just slip over the head of it and seat on the flange of the fitting and drive on this.
Charles
Don-Wi
11-25-2006 16:12:43
If it's already a through hole and it's off, you should be able to pound it through. Then I'd look at drilling and tapping it for a 1/4-28 threaded zerk instead. Of course, there's nothing wrong w/ a drive-in type as long as they all take grease....
Donovan from Wisconsin
JOHN HARMON
11-25-2006 15:00:45
I use a square tapered "Ez-out" that I got at Farm and Fleet if I remember right. Most Tool Supply Houses have round EZ-Outs which are spiral and will not remove a drive in zerk base in my experience. Just tap it in slightly and it will tighten as you turn it with a wrench.
