Tool Talk Discussion Forum
Rodac 3/8 air rachet
Kent of SW MO
11-24-2006 07:38:46
Where can I buy repair part for RODAC Air Tools?I contacted a local tool repair bussiness who claimed SNAP-ON took over RODAC and they were the only place I could buy repair parts. I talk to the local SNAP-OAN TOOL truck saleman who said he knew nothing of this. He also called SNAP-ON's tool repair division who also Knew nothing of this. I have a 3/8 air Ratchet that has lost the sping losded ball which hgolds the socket on. I need a replacment.
Kent
Slowpoke
11-29-2006 00:57:21
 Re: Rodac 3/8 air rachet in reply to Kent of SW MO, 11-24-2006 07:38:46
Go to your box of assorted ball bearings and select one that will work in the ratchet.
Kent of SW MO
11-29-2006 05:28:07
 Re: Rodac 3/8 air rachet in reply to Slowpoke, 11-29-2006 00:57:21
That was going to be my last resort but coming-up with the little spring is the tough part.
Kent
Slowpoke
11-29-2006 13:40:36
 Re: Rodac 3/8 air rachet in reply to Kent of SW MO, 11-29-2006 05:28:07
I wasn't aware that the spring was lost. Find a junked old manual typwriter or something similar. They have lots of small springs and other useable hardware. What is used to hold the spring and ball in place? If it's like a ratchet ball, it's difficult to get the metal peened over the ball. If it's a clip of some sort your're ok. If you can tell me what size spring you need, I'll look in my spring box to see if there's a match. If I do, it's yours. I need to know a close guess of OD, compressed length, free length, wire diameter, and #of coils. Use a mike or dial caliper if you have one. Whenever I find something with ball bearings that's not the least bit useable, I remove the balls or whole bearing if it's good. Same with springs and other stuff.
Slowpoke
12-01-2006 00:00:08
 Re: Rodac 3/8 air rachet in reply to Slowpoke, 11-29-2006 13:40:36
There is a device that in theory would work, but may not be practical because the part the ball is in is probably heat treated. It's a set screw with a spring loaded ball protruding from the end. You drill and tap for the size thread required and install it with a flat blade screwdriver. It can be driven from either end. I used one to hold a vice handle from droping down and pinching skin. The screw is adjustable for force so the handle won't move by itself. The screw was about 1/4" too long and was covered with a cap nut. Sorry, I can't remember the name of the thing.
Kent of SW MO
11-30-2006 08:48:05
I have not look into replacing the sping and ball that far. What I was most likly going to do was take a broken import ratchet, machine down the side oppsite the ball and retieve the ball and spring. The next problem would be peening the ball and spring into the Rodac part.
Kent
Sorry for the double post. I can not spell or type. Kent
Kent of SW MO
11-30-2006 08:46:30
I have not look into replacing the sping and ball that far. What I was most likly going to do was take a borked import ratchet, machine down the side oppsite the ball and retieve the ball and spring. The next problem would be peening the ball and spring into the Rodac part.
Kent
old_bc
11-25-2006 10:18:05
Americanpowertool.com has Rodac on the list of tools they repair. You might contact them.
old_bc
www.americanpowertool.com/repair.asp
Kent of SW MO
11-25-2006 15:42:37
 Re: Rodac 3/8 air rachet in reply to old_bc, 11-25-2006 10:18:05
Thank you!! old_bc.
Kent
