Tool Talk Discussion Forum
R12 or R134 ?
jack12345
11-22-2006 21:13:28
Is there anyway to test the freon gas thats in the system? A easy way without buying another tester/gauge? Thanks
banjo
11-22-2006 21:30:39
 Re: R12 or R134 ? in reply to jack12345, 11-22-2006 21:13:28
usually if it has 134a or been converted to 134a it will have the quick connect fittings. If it doesn't you might use the old gauges and see what the temperature/pressure should be for r12 and 134a. You can do it without it running, just hook the gauges up and see what the pressure reading is and see what the ambient temperature is and compare it on both.
Do you have the pressures/temp for 134a. ? if not i might be able to find some.
