Tool Talk Discussion Forum
OT 91 and 92 350 GM using antifreeze
Stumpalump
11-22-2006 16:00:19
1992 Buick Roadmaster and my buddys 1991 Suburban
both have a GM 350. They both use antifreeze but don't leak a drop. No water in the oil. Is this somthing common with this engine. Uses half gallon in two months consistantly.
bradk
11-22-2006 17:57:32
 Re: OT 91 and 92 350 GM using antifreeze in reply to Stumpalump, 11-22-2006 16:00:19
Pressure test them cold.Best time to find hard to locate leaks.
Look losely at: 1)intake gaskets
2)radiator
3)quick disconnect nipples
4)water pump weep(drain) hole
5)hose connections
~brad
onefarmer
11-22-2006 16:13:10
Does the radiator have plastic tanks? On my 98 Jimmy it leaks about that much around where the tranny and engine cooler are mounted. Nothing seems to seal it, and it doesn't leak enough to drip on the ground. It does vaporize enough coolant to smell though.
Allan In NE
11-22-2006 16:07:12
Burnin' it. Leaking intake maniforld gaskets.
Allan
B-maniac
11-22-2006 18:13:10
 Re: OT 91 and 92 350 GM using antifreeze in reply to Allan In NE, 11-22-2006 16:07:12
Alan in NE hit it on the head. Intake gaskets made of fragil plastic,break,leak into intake port. Eventually will take out oxygen sensor in exhaust. When you change them,get REPLACEMENT set as apposed to OEM set. The head and manifold surface will be very pitted where the seal was. The replacements will have the seal bead in a slightly different position so as to seal on the non-pitted surfaces of head and manifold. Do NOT overtighten!
504-1
11-22-2006 19:12:39
 Re: OT 91 and 92 350 GM using antifreeze in reply to B-maniac, 11-22-2006 18:13:10
Like Brad said check the heater hose at the manifold, they will leak and the heat will burn the antifreeze off so it dosn`t drip.
