Tool Talk Discussion Forum
Dumping oil on the ground
Stumpalump
11-20-2006 05:21:08
Found out my neibor is dumping his used oil on the ground along the fence line. Our wells are only 115' deep. He dumps that crap 200 feet from my well head. Is this illegal? His reply was "it came from the ground did'nt it". Should I kick his butt or what?
R Spence
11-22-2006 18:18:26
 Re: Dumping oil on the ground in reply to Stumpalump, 11-20-2006 05:21:08
I always dump my oil on the ground...I do not care LOL
Stumpalump
11-23-2006 09:24:35
 Re: Dumping oil on the ground in reply to R Spence, 11-22-2006 18:18:26
You probable don't bath regularly either.
paul
11-20-2006 18:43:59
Lots of used oil burners around 'here', you can give it away if you keep water out of it.
Fellow in Minnesota dumped a partial load of used oil on the ground back in the woods, just last week, don't know the motive, and it was _big_ news. You can google that story I'm sure.
Neighbor is in big big trouble if you want him to be.
--->Paul
Rockyhawaii
11-20-2006 17:45:21
I've found no-one that will take old oil for free, they want fifty cents a quart minimum.
dhermesc
11-21-2006 14:30:37
 Re: Dumping oil on the ground in reply to Rockyhawaii, 11-20-2006 17:45:21
Around here the mean old nasty Wal-Mart will take it 4 gallons at a time for free. My campany just signed a contract with some boys paying us .25 per gallon with a 50 gallon minimum.
Charles (in GA)
11-21-2006 02:25:28
Here in GA virtually every auto parts place has used oil containers. They take it for free, sell it to the recyclers. Its good for their business.
Charles
Charles (in GA)
11-20-2006 17:09:32
Politely ask the neighbor to quit. Offer that if he will save it in gallon jugs, you will take it to an auto parts place that accepts used oil (don't call it waste oil, according to the EPA, its USED oil) for free. Tell him you don't mind at all disposing of it for him, but please don't put it on the ground, you like your well water and want it to stay clean. Remind him that crude oil pumped from thousands of feet below the surface is not the same as pouring it on the ground after it is use.
If after working with him on it he still refuses, then consult a local code enforcement officer, see if they can help. Tell them what you offered, get them to go by and talk with him. Only as a last resort do you call the state EPA. If they come out it will probably cost him his property, since they will hire a EPA certified crew to come in and dig it all out, haul it off in EPA certified dump trucks to a soil burning plant, and he will have to pay for every cent of it. You don't want that, and he wouldn't either. The code man, while probably not legally able to do something, can "encourage" him by suggesting what a cleanup could cost. A little bit of authority goes a long way sometimes.
Charles
jughead 2
11-20-2006 16:28:03
it came from the ground...well I am glad to see that ignorance is still in abundance. Sorry to hear that you live next to this guy.
Aberdale Farm
11-20-2006 16:14:57
Hey there, Stumpalump,
I guess if someone was pouring used motor oil within 200 ft. of my well head, I would be concerned, too. It sounds pretty darned inconsiderate, or ignorant, for your neighbor to do that. Rather than turn him in, you might want to consider a water test from your well. If it's already affecting your well water, it would be good to know. If he just started doing it, then there's a chance that you may not find any contamination until a later date, or at all. You could send the neighbor the bill for the water test, and the bill for corrective action,, if any are needed to clean it up. But as some others have said, the EPA should be a last resort, because there's no telling what else they may decide to find while they are in your backyard. JMO.
Dale
Jon Hagen
11-20-2006 13:48:25
"His reply was "it came from the ground did'nt it". " Yes it did,very deep in the ground,below a layer of rock. Arsenic and asbestos came from the ground too,Would it be OK with him if you dumped a few hundred pounds of those materials in the fence line ??
Tim B from MA
11-20-2006 09:53:29
Tell him that if you see him doing it once more, you will call your state DEP/EPA. Dealing with used oil these days is so easy there is no excuse, except being a lazy a$$.
Oil is eaten up by microbes in the (dry) soil, and most metals will bind with the soil and be relatively immobile (zinc is one that can stay quite mobile). Unless he dumps more than an average home owner goes through, chances are it won't never reach your well water, but there are some circumstances where it might: your well is hydrologically downgradient from his favorite dumping spot(s); sandy soils, shallow GW table, tigher soils where your well creates a large cone of influence (i.e., the groundwater table around your well is depressed due to pumping).
However, if he dumps every time he changes his oil, his wife's oil and more, there will always be detectable oil in the soil, and there will likely always be elevated metals levels. Also, unless the GW table is very deep, there will also likely be detectable contamination in the GW near his dumping. As oil floats, you may have GW problems that will travel a considerable distance on the surfacw of the GW table, even though it does not impact a well that is drawing water from 100' or so below the top of the water table.
If these are purely residential properties, the chances of anyone ever sampling in the vicinity of the dumping is small. If the properties are now, or were ever farms or businesses, or properties near-by are commercial, chances of the bank sending someone to sample soil at property transfer / refinancing is higher. Finding contamination on your propery, or comming from your property is not something I would wish on anyone.
Dealing with environmental issues are a huge headache and even small issues are very expensive to deal with.
The bottom line is: why risk it having any contamination in your soil or your goundwater?
Good luck dealing with your neighbor.
Don-Wi
11-20-2006 09:32:40
I'm in camp 2 with Blus down below. It's illegal as heck to dump it. We do collect it in drums and use osme to oil our barn cleaner chain so I know we're not 100% innocent ourselves, but it's gotta get oiled and we're not just dumping 10 gallons in one spot. The trouble with reporting him, is he'll know for darn sure it was you who did it, and you'll be on his black list forever. The trouble with not reporting him, is you're just as guilty as he is.
There really isn't an easy way around this. If he's a guy you really don't care for anyway, go ahead and report him. If you get along with him, ya still gotta express your concerns and at the mot offer to get rid of it for him. I'd sure try to find out if someone would come and get it for free, or how much it would cost to dispose of it.
This is a very delicate situation you are being forced to be in, and I hope you and your neighbor can come to some sort of terms.
Donovan from Wisconsin
old
11-20-2006 09:32:21
If your state has a DNR or conservation dept call them and ask them about it. No matter what is no legal to dump oil on the ground and can be a big fine now days.
Dave F.
11-20-2006 09:31:35
I am all in favor for proper disposal of used motor oil, I have a small qualty of used anti-freeze. I would like to get rid of Who takes it? Thanks Dave F.
Eddie in MI
11-20-2006 18:53:18
 Antifreeze in reply to Dave F., 11-20-2006 09:31:35
Go to a local garage and ask. Usually they will dispose of antifreeze for you... I pay about $1/gal to dispose.
ScottP
11-20-2006 08:57:01
OK here's the problem.
When it is found that the neighbor has been dumping his oil on the propery line fence and you knew and didn't stop or report him you are just as guilty as him, so just start dumping you oil on the fence also. When the hazmat team does finaly come they will not only dig up his side of the fence but yours as well. You know who gets to pay for them to dig that huge hole in your yard, you do plus the fines.
One time the state was doing some shoulder work on a road. The crew found an old car battery sitting next to a farmers fence post. The battery was on the road side of the post. Out came the hazmat crew they dug a hole 10x10 and 20' deep to remove the contaminated soil. The bad part was the battery was still intact but just in case they dug the hole. The state charged the farmer for all the work. It doesn't sound like your neighbor will listen to reason and why should you haul away his used oil?
Give him a chance to clean up his mess then report him. Another thing to consider is what if that fence line isn't on the actual property line but a foot or so onto your place.
Midwest redneck
11-20-2006 08:27:23
Dont call the tree hugger nazis. He would be an enemy not a neighbor. Tell him that it is contaminating his well and yours. Offer to take it for free and burn it or take it to a waste oil place. I used to work with a guy that dumped it along his fence line, in the city, his comment was: "it comes from the ground dont it" (arrogant *ick)
dr.sportster
11-20-2006 08:08:49
Dont call the EPA/DEP on him.We all pollute a little and next they will be on your property.Talk to him again and maybe give him a 5o gal blue plastic drum.Waste oil is a commodity for heaters.An ounce of oil pollutes hundreds of gallons of water.There is alot of soil between your well and his dump site but it could still cause problems down the road.I treat my neighbors like I want to be treated and would never call the cops or goverment on them.I tell them if Im doing something to bother them let me know first.This has worked out fine.That and one side of my place is a swamp.Kicking his butt will lead to legal fees for the assault charges.Since it seems he knows you know and has responded" it came from the ground" tell him thats before it was processed with toxic stuff like zinc[disomethingicantspell].Dumping oil in the ground went out in the seventies.Any oil change place will let you dump it for free.If you call the DEP on him they will be digging out the whole mess as toxic soil.
glennster
11-20-2006 06:51:02
here is a link to a dandy set of plans for a waste oil burner made from an old hot water heater.
http://journeytoforever.org/biofuel_library/ethanol_motherearth/me4.html
souNdguy
11-20-2006 06:39:35
yes it is illegal.. contact the epa.. see what happens.
Soundguy
Mike M
11-20-2006 06:32:33
I take alot to other people who have waste oil burners,they are glad to get more. I also use some up when I need to burn some brush piles.
bjr
11-20-2006 06:26:43
I curious does anyone know if the counties quit oiling the roads? Are they exempt? What about the asphpalt leaching into the ground? bjr
souNdguy
11-20-2006 06:44:33
 Re: Dumping oil on the ground in reply to bjr, 11-20-2006 06:26:43
Different materials... 2 different animals.s.
Used motor oil is classified as a hazardous waste. It contains heavy metals .. etc.
Dust control oil, and bituminous 'tack' and water asphalt emulsions are all but environmentally inert once cured.. same with asphaltic concrete.
In most areas, dirt + concrete debri + asphalt debri are classified as 'clean' materials and are suitable for C&D landfills that are not lined.
( I'm a CE and work for a GC.. we do quite a bit of state and local municipality work ) Most of my college work was done in water systems engineering, including poloution issues.. etc.
Soundguy
Josh in Pa
11-20-2006 08:32:05
 Re: Dumping oil on the ground in reply to souNdguy, 11-20-2006 06:44:33
I'm followin in your footsteps. I'm graduating in december with a CE degree, focused in water resources, but am planning on taking a job with a GC.
Josh
souNdguy
11-21-2006 07:08:31
 Re: Dumping oil on the ground in reply to Josh in Pa, 11-20-2006 08:32:05
It's easier ( in my area ) to get on with a good GC than with a municipality.
Soundguy
John A.
11-20-2006 05:44:18
Stump, You might ask him too change places where dumps this oil! After you Calmly express your concern about water polution. For his waater well is in close proximity too like your! Pouring it out on his drive, will help keep dust and dirt from flying, will help keep the road material tied together May be a better opition. Or store it in a 55 gal barrel till it is full. There are companies that will come too your farm and pick it up for Free!
Or even better yet invest into an Oil Heater for the barn. Look at all that free fuel that is being poured out onto the ground. Just be sure to be Nice, and Sincere wen you visit with him, Most Good Neighbors will listen and try to help get-along with each other. Good Luck.
later,
John A.
Blue3992
11-20-2006 05:43:46
It's illegal as he11. Call you state EPA office if you want to report the guy.
Although, I suppose if you tick him off with a visit from the EPA and a fine, he may just start dumping it at midnight, right over your well or something.
Maybe first try to explain to him how you don't want him dumping oil, and tell him where he can take it to be properly disposed?
Blue3992
11-20-2006 06:02:45
 Re: Dumping oil on the ground in reply to Blue3992, 11-20-2006 05:43:46
Oh yeah, one other thing, I�m going to make a prediction:
Every time a question pops up about dumping used oil on the ground, you get a bunch of responses, all falling into two different camps:
1. It came from the ground, so why the heck can�t I pour it on the ground! Darn EPA and government intruding in everyone�s business!
2. It�s illegal, and furthermore it harms the environment. Take your used oil and other household hazardous waste to a proper disposal place.
And if you can�t tell, I�m a firm believer in camp 2. For a lot of reasons. Most importantly, it harms the environment. Your environment, right by your house. A lot of folks say, �Oh, its just a little bit, it can�t hurt.� Well, if everyone thinks that, then that�s a heck of a lot of oil that gets dumped every year.
Recycling your household hazardous waste is easy just about everywhere. Most any auto parts store will take used oil. And the rest of the waste (old batteries, paint, etc) can easily be recycled. Here in Illinois, they hold collections every weekend.
If that�s not reason enough, realize that in California, you now need a special license to buy auto paint. If you don�t own a body shop, you can�t get it. They had problems with people dumping old auto paint, so they just made it illegal for the average Joe to buy it. They tried passing a law that you would require a locking oil plug on all cars, so that you wouldn�t be able to change your own oil. That particular law didn�t pass, but it gives you an idea of what�s out there. Recycle your stuff; otherwise you give the rest of us a bad name.
Allan In NE
11-20-2006 05:29:16
Yeah,
I'd really be concerned. In about a million years or so, it will probably contaminate your well.
Allan
Dan Hill
11-22-2006 04:54:48
 Re: Dumping oil on the ground in reply to Allan In NE, 11-20-2006 05:29:16
Bad post.I did code enforcement for 15 years.Manure piled on ledge got in to a well 500 feet away.In Maine the CEO can summons your butt to court and represent the town.We have salt polluted wells and a town near us has a multi million dollar water system to serve a small number of homes because waste oil was dumped on the ground.There are several drilled wells polluted with gasoline within 400 feet of my place.The entire Main st buildings in the town of Corinna are gone because of chemical pollution from a woolen mill across the street.Ignorance is bliss.
Allan In NE
11-22-2006 16:05:56
 Re: Dumping oil on the ground in reply to Dan Hill, 11-22-2006 04:54:48
That's fine.
If you folks wanna live all piled up in a pile, that is your business; it's entirely up to you.
Allan
dan hill
11-23-2006 00:45:13
 Re: Dumping oil on the ground in reply to Allan In NE, 11-22-2006 16:05:56
These are rural towns, 1000 population 30 miles from large cities.Fuel oil costs 2.15 per gallon here.Used oil can be burned in furnaces built for it.A garage that does oil changes gets free heating.Why throw money on the ground?
4010guy
11-20-2006 08:42:48
considering the fact that i live out here in the middel of noware, I know were your comeing from allan.:o)..When you get over east your in a differnt world...
Nebraska Cowman
11-20-2006 05:23:51
I doubt his oil will ever hurt you. Use you own judgement but I'd hate to turn a neighbor in.
IH2444
11-20-2006 05:23:49
Dumping oil on the ground is very illegal. A $5,000 fine comes to mind, but I could be wrong on that.
Bill of TN
11-20-2006 14:18:50
 Re: Dumping oil on the ground in reply to IH2444, 11-20-2006 05:23:49
..... we all wonder why we don't know our neighbors..... .
I guess the best thing to do is never tell your neighbor anything.....
Any one remember the lesson learned many years ago about being a "tattle tail"?
By the way, is there any thing that isn't illegal?
4010guy
11-21-2006 07:33:12
 Re: Dumping oil on the ground in reply to Bill of TN, 11-20-2006 14:18:50
Bill of tn,,,,I like the way you think.
Amused
11-22-2006 15:25:14
 Re: Dumping oil on the ground in reply to 4010guy, 11-21-2006 07:33:12
And some of you wonder why this country is going to the dogs!The laws are in place for the benefit of society and people.If someone breaks the law,there are prescribed penalties and that lawbreaker is expected to be held accountable for their crime..."If you report him,he'll get mad,"might" retaliate"...Fine,then he;s commited another reportable crime.When did the "norm change from being a"law abiding citizen" to always seeing "what you can get away with.When laws are ignored,chaos results and society breaks down, Starts with the little stuff,educating your kids...speed limit 55,Daddy and Mommy always drive 70,slide thru stop signs,drive after drinking,throw their trash in an illegal dumpsite or along some back road,ridicule cops/DNR/Govt.The little folks see all this,learn that it's "proper" cuz Ma & Pop did it that way.If you have knowledge of a crime and don't report it,you can be charged as an accessorie simply because you did NOT do your civic duty to your fellows and either stop the crime or provide the information as to the perpetrator.You are also an enabler,your lack of caring and getting involved allows these crimes to occur.Yes,we don't like some of the "Rules",but we have the right to lobby to change them.I guess I'm odd because I was brought up to obey and respect All the"Rules",Gods and mans and have pretty much done so and will continue to do so.I'd have been into the chain of reporting that fellows oil dumping on discovery.1-Because it's seriously illegal,2-It is a major environmental threat to me my family and neighbors/community.3-Because of the dumpers ignorance and attitude.
dan hill
11-23-2006 01:14:01
 Re: Dumping oil on the ground in reply to Amused, 11-22-2006 15:25:14
I stopped at a small pond to fish .Some nice bass,no keepers.Very pretty spot, tall pines and hemlock.Picked up a dozen beer and soda bottles lying around.Looked along the shore for fishing spots, found 2 pick up loads of trash dumped, some of it in the water.Called the town clerk, she said the town road crew would take care of it.Stopped at a large lake, floating dock, concrete boat ramp,plenty of parking,3 trash barrels.Some low life had broken beer bottles on the ramp.Kids swim there.Picked up all broken glass I could find.Went home disgusted will litterbugs.Slobs hunting and fishing leave trash behind,Major cause of posted land here..
