Tool Talk Discussion Forum
97 Chev Van heater defrost
DCM
11-19-2006 17:37:03
The heater on the Astrovan only blows on the windsheild,the controlswitch for the dash and floor air direction quit functioning,what am I up against to get that control to work, Dan AB
azharry
11-19-2006 22:08:30
 Re: 97 Chev Van heater defrost in reply to DCM, 11-19-2006 17:37:03
The Astro uses small diameter hard plastic lines for the HVAC control vacuum. They often break by the check valve above the transmission dipstick. You'll also need to remove the engine cover and trace the line from the vacuum supply fitting on the left top side of the engine forward. They become very brittle and break from age and engine heat.
DCM
11-20-2006 06:13:22
 Re: 97 Chev Van heater defrost in reply to azharry, 11-19-2006 22:08:30
Thanks az,I would prefer to do that than try pull the dash apart and look for electronic components in the heater assembly that quit working.Dan
bradk
11-19-2006 18:46:46
DCM,
The HVAC controller's modes are controlled by vacuum,so if vacuum is lost,it will default to defrost.The first place to look would be the vacuum reservoir at right side under the hood.
You might have to take off the "dog house" to inspect all of the vacuum lines.
It could be the the vacuum switch at the selecter,but it will usually have a constant hissing noise.Hope this helps.~brad
DCM
11-19-2006 21:09:50
 Re: 97 Chev Van heater defrost in reply to bradk, 11-19-2006 18:46:46
Thanks Brad,its a start.Defrost is not the most efficient way to get heat.I will give the vacum hoses a look.Dan
