Tool Talk Discussion Forum
Tool Needed
Lil-Farmer
11-19-2006 16:30:57
I want to take a piece of slate and cut it into an intricate shape. Some small radius curves, and square inside corners.
I have tried scroll saw blades for wood and soft metals. They last about 2" into the cut, both with and without coolant. Also tried a carbide cutter for my Dremel tool without success.
Are there any scroll saw blades made that will stand this, as this is the tool I prefer to use? Checked Gemplers, McMaster-Carr, Lowes and Home Depot.
Any ideas out there?
Lil_Farmer
11-20-2006 17:53:23
 Re: Tool Needed in reply to Lil-Farmer, 11-19-2006 16:30:57
Thanks for all the responses.
The Speedster saw is probably the best answer, but I am not going to do this again for some time, if ever, there fore is cost prohibitive.
I still can not find 5" pinned scroll saw blades in either bi-metal or with a grit edge as some have suggested. Jig saw blades, yes, but the depth of the blade (fore and aft) is too much to allow the small radius curves I want.
While searching for scroll saw blades I did stumble across the "Rod saw blade" for use in a standard hacksaw. I have ordered one with the intention of modifying it to work in my scroll saw. It is nothing more than a .100 dia high tensile rod with diamond dust embedded in it.
Will let you know how it works out in a week or so.
Tim B from MA
11-20-2006 10:37:55
You can get the saber saw / reciprocol saw blakes with diamond grit glued to them at you local hardwater store. Should be fine for slate.
ScottP
11-20-2006 08:32:03
Lil
The tool you are looking for is called a Diamond band saw. As a Lapidary I can tell you that you have to use a coolant whenever you are cutting stone.
Your scroll saw is moving too fast to just use water. Try antifreeze and if you can slow down the speed of the blade. Check and see if there is a rock club in your area. Call and ask them for help, someone in the club may have a diamond band saw and make the cuts for you. I doubt they will do it for free as the blades are not cheap.
Scott
vitzarus
11-19-2006 20:33:02
Use carbide blades. You may have to trim for your saw or application. Carbide hacksaw blades have got me out of a jam afew times where I had to cut thru a bearing race.
D1D
11-19-2006 18:53:38
J.T.L.
11-19-2006 18:10:34
These sabersaw blades should work for you. The 2 I have are well worn out, but I have been useing them for over 30 years. The photo shows teeth on them, but they have a grit edge. Do a Google search for GRIT EDGE SAW BLADE to see more of them.
http://www.faucetdepot.com/faucetdepot/ProductDetail.asp?Product=18397&AffiliateID=GoogleBase
Dave Sherburne NY
11-19-2006 18:01:39
Some company used to make a blade that fit a hacksaw. It was round and had diamond dust stuck to it.
varmint
11-19-2006 19:14:23
 Re: Tool Needed in reply to Dave Sherburne NY, 11-19-2006 18:01:39
remington made one & called it a rod saw
Bud in NC
11-19-2006 16:45:12
I used to do some stained glass work - never had one of these but it sounds like what you're hunting - they AIN'T cheap, though!
They've been on the market for 15 to 20 years or so, so they should have the bugs worked out.
Delphi is one of the larger glass suppliers - you might find the same thing cheaper somewhere else but this'll give you some ideas of what to look for - good luck!
http://www.delphiglass.com/glass-tools/bandsaws/speedster-xl-bandsaw.html
