Keith Nicholson
11-20-2006 09:30:50
Re: Portable generator problem in reply to Keith Nicholson, 11-17-2006 07:05:34
Thanks to everyone for replies, these are some queries that came up: Size of generator: 5KVA, I think this gives about 4.6W. When I bought this size I balanced that the geni would be an emergency one, not one to run the house continuously, so fuel consumption came into it. If we had a long power outage the geni would run the gas central heating, necessary house lights and the fridge freezers in turn. The output at the generator: gauge on geni reads 220V, actual output matches both at the geni and at the end of the cable that goes to the fuseboard(distribution board). In the it fuseboard has a main breaker (Residual Circuit Breaker) and each house circuit has an mcb (miniature circuit breaker). The 2050W hot air gun was just used to test the geni, as was the electric drill (both to put a motor load on the geni) No fluorescent lights were on during tests or would be used if we get geni working and have to use it. During final tests all individual circuits were switched off at the fuseboard except downstairs light circuit and then with only one 100W bulb on - the geni is happy to run only a 25W bulb as a load. Geni internal configuration: using my simple logic after the independent test loads on the geni is that it is OK. I bought the geni new in the UK and the seller says he checks all geni's and has sold hundreds to domestic buyers like me with no problems. Breaker amperage on generator: don't know but geni has never shut itself down or tripped out despite being pulled down to overload and 100V. UK and USA service\utility company supply: I don't think UK is same as USA where there are two 120V supplies, we have two wires coming in, I guess live and neutral. Other work done recently?: no, the last person to do any work was the electrician. Single pole transfer switch: no, the switch is a two pole switching both live and neutral. Grounding: the electrician had to install a new earth system (ground spike) to meet modern standards. With the ongoing problems the electrician suggested the geni needed its own earth ground spike, made no difference to prob. Wiring to connecting plug: the electrician wired up the plug so I assume he got it right. Who should find the problem?: the electrician can't solve the problem and until I can pinpoint the problem I am 'keeping my powder dry' but if I find it would have been reasonable for him to have found it, then ..... I have written to him today, but staying cool, and saying that if he believes our electrical fittings are the problem and that by testing them and renewing where necessary, this solves the problem I will pay. I also said that if he can't solve problem I will call in a consultant electrical engineer and if he says the electrician should have been able to find the fault and\or has made a mistake then I will go from there. Here I am way out of my depth: it seems to me that in the olden days there was just Live\hot, neutral\negative and earth\ground, now it seems that the neutral can somehow be used as an earth. My gut feeling is that the problem lies in the neutrals, or a mismatch of, in combination with the earths but I am guessing. Someone said they would need to be here to crack the problem and I can understand that. I fix laser printers and most probs are just one fault and a check-over. Yet after 10 years at it I still get the occasional fault that I have to walk away from for an hour and rethink everything and I would never have solved the fault at a distance. With the tests I have done, although real with results, I don't have the knowledge to make joined-up sense. I know an electronics and electrical wizard who I have pestered into possible helping me, I keep going into his office with a hangdog look (hope he's not reading this!), he may be coming in this afternoon, so fingers crossed. When the fault is found I'll be back. Thanks everyone. UPDATE The upper light switch was changed and there is now no 24V AC leakage to the light unit - the 40 year old light switch was stripped and was in a very dirty condition inside with a burnt contact. (the lower hallway light switch was also renewed). The geni was started-up with the change over switch (c\o switch) on mains supply, no effect on geni. With geni running the c\o switch was switched to geni and the main Residual Circuit Breaker (RCB) on the fuseboard\distribution board went to 'off', I could not reset RCB. The power switch on geni unit switched 'off', now could reset main RCB, geni switch to 'on', RCB tripped out again. C\o switch to geni, all mcb's (miniature circuit breakers to individual house circuits) 'off', geni running, geni power switch 'off', geni switch to 'on', RCB tripped out. Same test as but with all mcb's 'on', geni switch to 'on', geni went down to 100V. The whole situation has worsened in that before the geni would connect to the house circuit through the c\o switch but with just the lower hall circuit 'on'- all other individual circuit mcb's (miniature circuit breakers were 'off'), now it won't connect at all. (the two main cables going into the fuseboard are the same colour)
