Tool Talk Discussion Forum
Sand blaster clogging up
hogman_2002
11-16-2006 20:54:00
I have a pressure pot blaster that you can buy at Tractor Supply. I was trying to sandblast some wheels today but wasn't having much luck. It seems to be plugging up below the cut off valve on the bottom of the tank. I can pull the hose off and run a piece of wire in the mixing chamber to clear the clog. But when I put everything back together it'll work for a minute and then clog up again. I have used this blaster before and had good luck. It did clog a few times at the nozzle, but that was because I didn't sift the slag I was using. Does anyone know what could be causing this?
hogman_2002
11-18-2006 17:32:38
 Re: Sand blaster clogging up in reply to hogman_2002, 11-16-2006 20:54:00
Thanks for all the help. I put a dryer between the hose and blaster and was still having trouble. I then took off the hose under the tank and looked in the mixing chamber. I could see something in there and couldn't pull it out with a piece of wire. So I took it off and sure enough there was 1 inch piece of a 3/32 drill bit stuck in there. How it got in there, I don't know, but it was in there. After putting everything back together, it worked as it should.
genos
11-18-2006 16:01:33
I Have A 110 lb. Blaster And Have Done Lots Of Blasting In The Past Ten Years, Have Water Trap In Compressor Line And One On The Blaster And Still Have Learned Not To Blast If There Is A Hint Of Moisture In the Air, Do It On A Sunnny Day Just Like Painting Outside. I Have Very Little With Plugging Up Doing It This Way. I Sure Used Too Though. Also Store Your Media In A Dry Area Too.
NE IA Dave
11-17-2006 20:22:08
I have a half dozen different sandblasters, always trying to get a better one. Like the others have said about the moisture, it is perhaps your biggest problem. In addition I will tell of another trick that works on most of them is---Do this carfuly and slowley the first time---You should be wearing rubber or leather gloves, I have never had anything go wrong by doing this I might add, but just suggest caution. Take the nozzle and with the trigger shut off, hold the nozzle very tight to your glove and squeeze the trigger. This will force air backwards in the feed tube / pot. Most times this will get her going again. You mentioned TSC blaster, I put my foot under the valve lever and open / shut it down a little, this is by no means a easy task, but sure beats getting my gear off and bending over my big belly to mess with the valve. You can blow those cheap hose clamps off doing this if your pressure is real high. I must also mention a year long problem I had with a couple of my blasters. I have always been at the bottom end of the pole when It comes to affording the better things in life, Like a very large air compressor. I have been known to hook up extra tanks, and taging two compressors together for sand blasting, and still running out of air pressure. I was fortunate enough a few years ago to get a bigger compressor, a real 5 HP. Not the box store carry in one hand with a bag of sand in the other type of 5hp. I was pretty disapointed in the sand blasting, never run out of air, in fact the compressor would shut off often. A year later a guy at the body shop told me to read the directions that suggested the max. psi. for the blaster. More is not always better in all cases, I turned the pressure down, and it works a lot better now. NE IA Dave
old
11-17-2006 08:25:53
I had the same problem with the one I have. I ended up removeing the valve and now it works just fine. I just use the preassure valve to turn it on and off now and haven't had a problem with it since
RustyFarmall
11-17-2006 06:11:53
Moisture in your compressed air. You need to install a water trap in the air lines, or install one of those air dryer units.
jeffcat
11-16-2006 23:19:50
I'll ditto that with the water. I have a little 20lb pot from Harbor Freight and it works great. When it is the middle of the summer it would start to plug up. If you wiggle the feed valve and the nozzle is pointed at your work you should get a big BLORP and a big wet spot on the work. That is water from your line as the air cools. I have a big old cast pot metal seperator from the 60s screwed to the side of mine. Takes out all of the water. Get at least a one quart size for a blaster. You will not beleave how much water can come out of an air hose. Almost looks like a garden hose sometimes! Jeffcat
Paul in On
11-16-2006 21:30:33
Was it raining were you were today? high humidity will probably do that.
Jon Hagen
11-16-2006 23:15:05
 Re: Sand blaster clogging up in reply to Paul in On, 11-16-2006 21:30:33
Any chance your TSC sand blaster is like mine ? Mine is made to spray dry sand or liquid. The hose barb on the bottom of the sand tank is quite long,and must have the hose pushed on only far enough to keep the hose connected,but not so far that it covers the air bleed hole in the side of the hose barb when using dry sand. If the hose is pushed fully on the barb,covering the hole,it will clog the hose with sand after a few seconds. The "hose pushed fully on the barb" position is only for spraying liquids. HTH Jon H
