There's a little misunderstanding here. When you turn the key "ON", the 'PUTER cycles the pump on for a couple of seconds, using the fuel pump relay. When you turn the key to "START", as soon as the 'PUTER realizes it's getting pulses from the ignition pickup, it again turns on the fuel pump relay. If the fuel pump relay is bad, or there is a problem in that circuit (or the 'PUTER), there is a backup system, the oil pressure switch, that is also capable of turning on the fuel pump, once the engine has cranked long enough to build up oil pressure. So, your problem lies in the fuel pump relay or the 'PUTER or associated wiring between the 'PUTER and the fuel pump relay. The OIL PRESSURE switch is working as it's supposed to, providing the backup means to tuen on the fuel pump after some cranking, or the truck wouldn't be starting at all. Start by listening under the hood for the fuel pump relay to click in and out, while someone else turns the key on. (The relay is located under the removable electrical cover on the upper RH side of the firewall.) If you hear the relay "click", it's contacts MAY be bad, or if it doesn't click, it's coil may be bad, or the 'PUTER, or wiring, as previously mentioned.
