Welding Help
Rod MI
04-01-2001 13:52:27
My Brush Hog has 4 cracks around the gear box bracket and I'm wondering what welding rod # and size and how many amps should I use to weld this the steel is 1/4 inch by 2inch and the crack is about 1/4 to 1/2 inch long and I have a Lincoln 225amp AC welder and is any one aware of a recommendation chart for selecting the right amps will 6011 rod work ok and what size thanks for help this is the first real welding job with this welder
Bob Carroll
03-04-2004 11:40:20
 Re: Welding Help in reply to Rod MI, 04-01-2001 13:52:27
I am doing a weld build up on a CD4MCu pump case using dulex SS electrode E2553-16. Having some problems. Anyone have experience with duplex SMAW ??
Rod MI
04-02-2001 22:52:38
thanks all
BFO
04-02-2001 19:38:53
Rod, the 6011 would probably work fine. My personal choice in this situation would be to use 7018 AC, but use what you have. Practice on some scrap first. For 1/8 rod start at 120-125 amps and get the feel for it. Every machine is different. Have fun!
Matt
04-02-2001 17:36:09
If you use 7018 be sure to get a rod made for AC.
Sage
04-01-2001 14:04:13
You need to wire brush the paint off of the crack first. Second, you need to drill a hole at each end of the crack. This is the best way to stop the crack. Third, you need to grind a V into the crack with a grinder. Fourth, I would use a 7018 at about 130 or 145 amps to weld the crack with. This should fix your problem.
Rod MI
04-01-2001 16:39:31
 Re: Re: Welding Help in reply to Sage, 04-01-2001 14:04:13
Sage thanks I will give it a try next weekend
