Be careful about comparing an installed price including support and a warranty against a "pump in a box" price. You'll need a crane and hoist arrangement to replace a submersible pump if the current one is hanging from threaded drop pipe. Drop pipe for a well usually comes in 20 foot lengths, the pipe is full of water and has check valves keeping the water from draining back (i.e. very heavy), so you need a pretty tall and capable crane. If your well is relatively shallow, the pump may be hanging on poly pipe, which is much easier to handle. Dean Bennett Supply sells Flint and Walling submersible pumps, which are US made of stainless steel and seem to be of good quality at a good price. They have a "do it yourself" section that describes tools like the "skillet" and "bail", and the general concepts of how submersible pumps work and how they should be sized. I purchased a 3HP 3 phase pump from Dean Bennett, modified my backhoe to create a 20 foot capable crane, used a home-made skillet and bail, and set the pump 300 feet down in the well using threaded PVC drop pipe with stainless steel couplings. I drive the 3 phase pump motor using 240 VAC single phase power converted by a VFD (this lets me get away with a smaller pressure tank) This setup has given excellent service for 3 years and counting. It is capable of 27 GPM at 100 PSI at the surface. But it probably took me a couple of weeks of surfing and reading to learn how to do all this, and a whole day to set the pump. I risked personal injury and economic injury (from dropping the pump to the bottom of the well). This kind of project is not for the faint of heart. Flotech makes pressure tanks, check valves, and a number of other well accessories. Since their producs are sold in big box stores, I suspect their pumps are made in China. As with many things made in China, production quality is likely dependent on supervision by the parent organization. The pumps might be fine, or they might be junk.
