Tool Talk Discussion Forum
Blinker Control 1994 Olds Cutlas Supreme
Duane WI
11-13-2006 06:43:56
Can anybody tell me where to find the blinker control relay on a 1994 Olds Cutlas Supreme? I took the underside of the driver side dash apart but couldn't locate it. My blinkers have been acting funny. Slow blink rate, fast blink rate, sometimes just stay on, sometimes not come on at all. I assume that there is some type of flasher control timer relay that is going bad. What would it look like and where would if be located? Thanks for the help.
bradk
11-13-2006 07:02:49
 Re: Blinker Control 1994 Olds Cutlas Supreme in reply to Duane WI, 11-13-2006 06:43:56
Duane;
Does the flasher speed change if the lever is held in a certain position or work/not work at all?Have you smelled a burnt type of smell?
Also,turn the park lamps on and the 4-way flashers to check the outside lamps.~brad
Merc Teach
11-13-2006 06:50:48
It could be your multi function switch. This is the switch in your steering column that controls blinkers, cruise, wipers, etc. This is a common failure. Blinkers are always first to go. If you still want to look at the relay try behind the glove box. I am betting it is the MFS ($$$$$).
