Tool Talk Discussion Forum
Temp heater
msb
11-12-2006 19:39:46
Have a 40'x56'x10'eave height pole building w/concrete floor.Totally uninsulated. Going to install a ceiling and insulate the building later ths winter after the crops are in.Have a lot of tools stored in it at present.Need something to keep the humidity from rusting everything until I get some permanent heat installed.Don't have time to babysit a wood stove. Have a 1000 gal. LP tank right outside that supplies the furnace in the garage.. What would you suggest for now and after insulation is done.?
Steve Crum
11-13-2006 04:45:34
 Re: Temp heater in reply to msb, 11-12-2006 19:39:46
third party image
Not monkeying around with salamanders this year.
Putting in a permanent 130,000 BTU oil fired unit in the plasma building.
old
11-12-2006 19:44:02
Find a mobile home furnace that is propane. Most of the time you can find them for around $100 or less and they still work well. You might even check with a dealer he may have an old trade in that hes junking out
135 Fan
11-12-2006 19:51:17
 Re: Temp heater in reply to old, 11-12-2006 19:44:02
You could rent or possibly buy a propane construction heater with a thermostat. I've also seen small ceiling mount heaters that run on propane for heating garages etc. Dave
David - OR
11-13-2006 04:49:40
 Re: Temp heater in reply to 135 Fan, 11-12-2006 19:51:17
If the objective is avoiding rust, you probably don't want a "temporary construction heater". These are usually unvented, so all the water vapor produced by burning the propane gets released into the air of the space you are trying to dry out.
C3H8 + 5O2 -> 3CO2 + 4H2O
Some sort of furnace with a "B" vent would be a better plan. The combustion gasses get dumped outside, the heat helps to drive off the interior moisture.
old
11-12-2006 20:05:07
Dave, why do you always answer my post instead of the post the guy asking the question posts. You need to click on reply in his post not my post to answer his question. LOL
135 Fan
11-12-2006 22:54:07
 Re: Temp heater in reply to old, 11-12-2006 20:05:07
I just put it in order so he would see your post first. A propane furnace is a good idea. I know a guy that uses one in his 3 car garage. Sometimes I'll put my post first if there is some bad advice like filling a gas tank with gas to braze it with a 3000 Deg. torch. Your advice is a lot more common sense than some. Dave
larry in tn
11-13-2006 03:59:55
 Re: Temp heater in reply to 135 Fan, 11-12-2006 22:54:07
I reads em all anyhow so if you miss a cogg its OK.
